Active Member
Cab Dolley
Looking for plans on making a cab dolley seems like I saw one made out of 4x4 lumber about 2 years ago.
Thanks |
same here
67 chevy stepside, 6 cylinder, three on the tree, small window. Currently in resto. |
Here is a pic of one I made recently for my blazer tub and it works great. I can get you demensions if you need them.
67 short wide 355ci 3 on tree 69 short wide 250ci 3 on tree 68 long wide 283 3 on tree 72 2wd Blazer project 454 5 speed ![]() |
67 is sold
We made a retangular dolly for our Camaro shell a few years back. Four 4x4 treated posts bolted togetther on big casters similar to what ChevyFarmer posted.
My cab is not setting on it ![]() |
![]() Join Date: Dec 2001
Here's mine, I made it long so I could tilt the cab back and clean/paint the underside as well.
1942 Master Deluxe 1969 C/10 1985 Blazer CUCV 1987 Jimmy 2004 Tahoe 2005 Silverado 1500 2005 Silverado 3500 |
72 BB C30 Super LongHorn
![]() Join Date: Nov 2002
I was planning to build one from square box tubing as a rolling table, with legs that have a smaller tube box inside so I could raise and lower the platform to clear the frame when I take off and re-install the cab. I would use the floor jack to raise the cab up, then, remove the fixed pins at the heighth that I wanted it, then re-install the pins to clear the frame. I have a design for it, using casters to move it around the yard, but I have yet to fab this up....
72 BB C/30 Longhorn Super HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM HO72 build : http://67-72chevytrucks.com/vboard/s...d.php?t=714492 2017 SS ![]() |
RPOZ11, that's a great idea to have adjustable position legs. Probably less tippy off the vehicle with lowered legs.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. |
Where's my beer?
I like the designs, but as a suggestion I'd put soft wheels on it, it would make it a lot easier to move around. I move office furniture all day for a living, and we ditched the hard wheels on all our carts for soft ones, and it makes a helluva difference. I'd be willing to bet a fully loaded cart with panels could weigh close to what a stripped cab weighs.
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam. 79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam. '03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great '08 Tahoe LTZ 4x4 155K |
Never Done?
![]() Join Date: May 2000
I picked up a bakery cart out of a dumpster at a local Sam's Club (friend works there), and it works great for what I need.
i always make mine out of scrap lumber, they're quick to fab at less than an hour and easy to modify. i like bigger size wheels also makes for easier rolling . i get wheels at the harbor frieght store
71c-10 350/2004r/4:11 lowered3/4 longbed/dead by hurricane MEANING OF DEATH::::: SOMEBODY ELSE GETS YOUR STUFF DONT BELIEVE EVERYTHING YOU THINK TAKE MY ADVISE;I DON'T USE IT ANYWAY Last edited by cdowns; 05-12-2006 at 08:06 AM. |
Active Member
I Got some free 2x2 steel . I made a dolley this weekend same basic design as chevyfarmers dolley I will try to post a picture the first of the week.
Someone posted these dimensions and pics about 4 years ago. Sorry I didn't save original posters name.
Mine is similar but I raised the height of the bottom side board so I could slide my cherry picker under the whole dolly to lift cab. I showed it in the last pic. I also changed the dimensions alittle on mine as far as where the dolly meets the cab. Personal preference I guess.
#13 |
I bought this little "cab" dolly at a local tool rental about three (3) years ago for $200.
The great think is when not using for a cab you can use for so many other things!! Last edited by jec; 07-03-2005 at 11:59 PM. |
