Old 06-29-2005, 08:33 AM   #1
fade94
fade94's Avatar
Question Need picture of heater hose setup
We have an 83 Chevy truck. The carb on it is a dual inlet Holley. The issue is the feed tube for the carbs is right on top of the heater hose inlet on the Torker intake. I need to see pics of how some of you have resolved this issue.
68 short bed driver (71 clip on it now, swapping to 68 when weather cooperates)
67 short step project (will get SWB from the 68)
67 Camaro, #'s matching (my wife's)
03 Dodge Ram 2500 4x4 diesel 5 speed 4.10 rear
fade94 is offline   Reply With Quote
Old 06-29-2005, 10:40 AM   #2
86 GMG
awero quip makes 90 deg. fitting if that wont work you can purchase a carb. lift plate (spacer) or you can plug the intake and put your heater hose to the top of your water pump the only problem with the water pump is it seemed to not blow hot enough through the heater this might be an easy fix to correct that i dont know about best of luck
square body trucks an addiction or an investment either way they consume all my extra time and money
86 GMG is offline   Reply With Quote
