Old 06-29-2005, 01:44 PM   #1
KEH
Better late than never
KEH's Avatar
Cooling system flush
I have a new 4 core radiator that I will be installing soon and want to flush the old coolant. I know the flush systems that can be bought at the parts store require cutting a heater hose.
Is there a better way though?
1970 C/10 SWB Stepside
KEH is offline   Reply With Quote
Old 06-29-2005, 02:15 PM   #2
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
you can remove the drain plug on the engine some engines have a petcock on them and i would remove the thermostat and install a new one when you exchange the radiator and new hoses as well
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 06-29-2005, 05:57 PM   #3
flip66
flip66's Avatar
I used one of the flush kits I just put it in place of the heater control valve did the flush and put the control valve back in. I guess if you dont have a heater control valve it would not be that easy.
1998 Pontiac Grad Prix GTP
1969 C10 396 TH400 3.08 posi
flip66 is offline   Reply With Quote
Old 06-29-2005, 08:16 PM   #4
Fred T
Cantankerous Geezer
Fred T's Avatar
If you go to the hardware store you should be able to buy a plastic hose adapter fitting or a hose mending fitting that fits 5/8" hose. That will allow you to hook onto a heater hose. I also use a shut-off valve so I can easily control the flow. If you put full pressure in the system, you can blow out the heater core, which is designed for 17 psi, household water usually runs 40-60 psi. This is also a good time for a new thermostat.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 06-29-2005, 10:26 PM   #5
KEH
KEH's Avatar
Thanks for the responses and good ideas.
