Old 06-29-2005, 02:04 PM   #1
KEH
Better late than never
KEH's Avatar
Fan/Shroud position
My fan currently sits totally within the throat of the shroud (the rear end of the blades are about 1" from the rear of the shroud). I am replacing a 3 core with a 4 core radiator and this will bring the fan further inside the shroud.
I read somewhere that the fan should have blades outside of the shroud about 1 inch for best performance. Is this true?
1970 C/10 SWB Stepside
KEH is offline   Reply With Quote
Old 06-29-2005, 04:42 PM   #2
neonlarry
neonlarry's Avatar
Yes.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 06-29-2005, 05:38 PM   #3
cowboy33713
Howdy:
talk to the fella at Manes Truck parts; the "heavy duty" fan shroud puts the fan blade further inside the shroud.
hope this helps.
cowboy
cowboy33713 is offline   Reply With Quote
Old 06-29-2005, 07:09 PM   #4
Stocker
20' Daredevil (Ret)
Stocker's Avatar
The 4-row radiator I put in my truck was externally the same size as the OEM 3-row; only the core is thicker, so the fit was the same.
That said, the fan sits half in and half out of the shroud. Never had an overheating problem, even in extreme conditions - even with the 3-row, and I've owned the truck for 28 years.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 06-29-2005, 07:30 PM   #5
tomatocity
tomatocity's Avatar
agree with Stocker, half in and half out. Do you have the correct fan and/or water pump (long or short)?
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck.
tomatocity is offline   Reply With Quote
Old 06-29-2005, 10:16 PM   #6
KEH
KEH's Avatar
The 4 core I have is 3/4" wider than the 3 core at the top mounts. I need to find new mounts.
It has a long water pump. Here are some pics. I think maybe I should cut the adapter that sits between the fan and the pump shorter?
Old 06-29-2005, 11:59 PM   #7
pjmoreland
pjmoreland's Avatar
If you cut the adapter shorter, you had better have it done on a lathe. Otherwise your fan will not spin straight and will probably vibrate. I've seen adapters of various lengths for sale at auto parts stores.
pjmoreland is offline   Reply With Quote
Old 06-30-2005, 12:02 AM   #8
KEH
KEH's Avatar
Very good point PJ. I will look for a shorter adapter to buy.
Old 06-30-2005, 12:46 AM   #9
tomatocity
tomatocity's Avatar
You should be able to find a smaller adapter. If you cut the adpter and it is not straight iot will shake the water pump until it breaks.
