k20 vs. k30
What are the main differences between a 3/4 and a 1ton truck for the 73-87 era? If memory serves the 1 ton have stronger/stiffer springs, and the dana 60 front axle. Are there any other differences that I am not aware of, frames, brakes, steering, tires, etc? (other than a 1 ton being optioned with a drw setup that is).
Thanks |
frames are thicker on the K30s, rear spring perch is narrower. thats about it.
comments
I think there's more to it than that? I believe the upper control arms are larger along with the brake calipers. I'm sure this can be added too.
MK |
#4 | |
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
K trucks dont have upper control arms.
![]() yes, each axle has it own brakes, but that is to be expected. all rear brake options on a 14FF are available on both 3/4 and 1 ton trucks, depending on GVWR. |
