Old 06-29-2005, 06:27 PM   #1
locab36
locab36's Avatar
Tilt column questions
I finally bought a tilt column for my 69. The column I got is tight but the pointer is broken off and the housing and indicator have seen better days. I know I can buy all these parts from vendors like GMCPauls. My question is there anywhere on the web that has a detail of rebuilding the columns or diagrams of assembly? I have some damage to the shift housing and dents in the signal switch housing where do I get these parts new/used?
John in MI
Locab36
1936 low cab 1/2 ton
1956 BMW R25/3
1968 Moto Guzzi V7
1969 BMW R100/2
1986 Silverado SWB
2007 Harley FLHTP
2011 GMC SWB 4x4 Z71
http://www.flickr.com/photos/locab36...7623329816080/
locab36 is offline   Reply With Quote
Old 06-29-2005, 06:43 PM   #2
Hart_Rod
Hart_Rod's Avatar
Try here:
http://67-72chevytrucks.com/vboard/s....php3?t=133937
http://67-72chevytrucks.com/vboard/s....php3?t=157328
Rob
Hart_Rod is offline   Reply With Quote
Old 06-29-2005, 08:02 PM   #3
Fred T
Cantankerous Geezer
Fred T's Avatar
If you have to break down the column, a pivot pin puller makes things a lot easier. Several brands available. http://www.lislecorp.com/tool_detail.cfm?detail=190
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
