06-29-2005, 08:39 PM | #1 |
Java Mechanic
Wanna know what is worse than rust?
What's worse than rust? ...
Uncovering "creative" repairs from years gone by... I am going to need to do just a bit more work than I realized at first. The following pictures can be called Red Neck Engineering One, Two and Three and pile-o-crap. They could be the center peice for a Jeff Foxworthy joke. Note the ingenious use of chicken wire, the unsparing application of (gee, I don't know... about two pounds maybe?) bondo and the four sheet metal screws holding the entire contraption together. Oh.. yes the seatbelt *was* bondoed in place... |
06-29-2005, 08:43 PM | #2 |
Designated A-hole!
That's insane! Wonder what else you're gonna find?
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
06-29-2005, 08:46 PM | #3 |
I thought that was factory stock, every truck in Virginia has that stuff.
06-29-2005, 09:00 PM | #4 |
55454
I thought Va. and La. is where you get all the original paint one owner trucks. Or should I say Va. to La.
06-29-2005, 09:06 PM | #5 |
Maybe the guy was a old wall plaster man. Looks like a drywall repair gone bad...
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. |
06-29-2005, 09:11 PM | #6 |
Where's my beer?
Ok, I thought my truck was bad, but I have to say, that one's got me beat. Rust wise and redneck engineering wise!
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam. 79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam. '03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great '08 Tahoe LTZ 4x4 155K |
06-29-2005, 09:22 PM | #7 |
Hate to admit it, but I made a temp. fiberglass patch for my floor prior to committing to the restoration. Kept me warmer on those snowy winter drives to work, and the sight of seeing asphalt through the floorboards wasn't very comforting.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. Last edited by Sweet72; 06-29-2005 at 09:23 PM. |
06-29-2005, 09:49 PM | #8 |
its all about the +6 inches
That is actually a normal fix back in the 70's. My old 68 Cougar had and formed quarter panels. They started with a sheet of cardboard, and then molded a panel on top of it with plastic filler, then sprayed the inside of the trunk with undercoating.
06-29-2005, 09:53 PM | #9 |
The LuvShack Garage
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
06-29-2005, 09:57 PM | #10 |
F.A.S.T. president
thats just plain dumb.........they used the wrong wire mesh size for bondo........
F.A.S.T. President and Founder Fabricators for the Advancement of Sawsall Technology "A fear of the Sawsall is a sign of retarded sexual and emotional maturity." ~Sigmund Freud, "General Introduction to Psychoanalysis" |
06-29-2005, 09:59 PM | #11 | |
06-29-2005, 10:07 PM | #12 |
Java Mechanic
I can't wait to see what's on the driver's side..
I poked around a bit and discovered that they sprayed pipe insulation foam into the void on that side. Guess I'll have to pull the tank afterall... |
06-29-2005, 10:13 PM | #13 | |
Wierd thing was, you couldn't tell with the carpet in place
If patience is truely a virtue, Then I am so screwed 1970 Chevy SWB 331 sbc and all the goodies. Under resurection 2001 Vette |
06-29-2005, 10:21 PM | #14 |
Excelsior, You Fathead.
It least mine just has holes. I didn't have to pull all that junk out of the body.
Go Navy. The Sea Is Ours. Budget 350 Build http://67-72chevytrucks.com/vboard/s...38#post2264638 |
06-29-2005, 10:37 PM | #15 |
Half a bubble off!
Dayum! Did they hack the dash and cut speaker holes in the doors too?
Just call me LB. '71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads. |
06-29-2005, 11:03 PM | #16 |
Java Mechanic
The dash is hacked a bit.. but no holes in the doors.
06-29-2005, 11:46 PM | #17 |
technicality
Just so the "rednecks to be" know what to buy, that wire mesh stuff is called hardware cloth. Chicken wire has more of an expanded oval or hex shape to it.
06-29-2005, 11:46 PM | #18 |
my first cab had cab corners made of spray foam, luckily for me the day i discovered it, i found a cab a guy in town was selling, i just ditched it and moved on
06-30-2005, 12:47 AM | #19 |
Saving 1 truck at a time!
Those repairs are unbelievable! Andy...bondo and cardboard? My '67 had fiberglass fender repairs and fiber glass cab corners! Here I thought it was a prototype...LOL! I tossed the fenders...too far gone but am going to fix the cab once I get my current cab project done! Where does it end?
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
06-30-2005, 01:33 AM | #20 |
My rockers and cab corners are mono foam and aluminum foil, the floor on the drivers side was cardboard wrapped in a garbage bag and beside the gas tank on the passenger side was a garbage bag filled with mono foam to fill the giant hole. The lower front fenders are rags soaked in resin, and the box floor is a piece of roof tin siliconed in place. Thank god for repro parts and parts trucks.
1964 Chevy Short Fleet: Tornado 1972 Chevy C10: Fast Orange Secondaries Wide Open |
06-30-2005, 07:29 AM | #21 |
Java Mechanic
Wow Mud.. I feel much better now! lol
On this.. does anyone have any pictures of the sill area with the carpet back and sill plates off? I could use a reference when I start rebuilding the area. |
06-30-2005, 08:03 AM | #22 |
Not sure if this is what your looking for but here's a couple rocker/floor pics.
Good luck. I feel your pain as well, one of my blazers had that spray in foam acting as a torsion box. |
06-30-2005, 08:13 AM | #23 |
Java Mechanic
That will be very helpfull -- thanks bunches!
06-30-2005, 08:53 AM | #24 | |
If you need more pics of detailed areas, let me know. It's still sitting with no carpet or anything covered up or installed. |
06-30-2005, 09:31 AM | #25 |
Java Mechanic
I'll look again tonight and see what still looks baffling. On the driver's side I am simply going to fix it but I am planning a small mod for the passenger side. I want to make the channel that runs along the edge of the cab considerably larger than stock to facilitate hiding a bunch of cables.
In the absolute rear corner of the cab... Does the floor of the cab slope off and meet the outer cab corner wall at a point? If yu look at my pictures at the top; did the necks have the basic shape right? This isn't an area you ever really study in detail until you find something like this. lol Should the cross section look like: (ignore the dots.. they are place holders..) |..____ |/ |
