Old 06-29-2005, 09:37 PM   #1
dennislbrooks
dennislbrooks's Avatar
Spindle Question
I have a pair of disc spindles with backing plates and rotors. The spindles look like 72 chevy C10 spindles however they have a larger inner bearing. From what I can find out the 1986 GMC C15 may have had an option for 2500# front spindles (normal C10 spindles are 1500#) with the same 5 on 5" bolt pattern.
Can I use these spindles on a 67 C10 if I use 72 upper/lower balljoints and 72 tie rod ends? The rotor diameter and thickness are the same as a 72 chevy.
Anyone heard of these spindles? The inner bearing box is Timken LM45858.
thanks
dennislbrooks is online now   Reply With Quote
Old 06-29-2005, 10:41 PM   #2
68C15
blood type; Retumbo
68C15's Avatar
is that the heavy half with the 1.250 thick rotors?
all the parts you mentioned will fit the older arms. thats what I did.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 06-30-2005, 02:28 AM   #3
JDL
JDL's Avatar
Yes use them.
72 Chevy short step side with 454 air and tilt.
72 nova project car
63 chevy II drag car
Agency Iowa
JDL is offline   Reply With Quote
Old 06-30-2005, 06:57 AM   #4
dennislbrooks
heavy half???
I looked at the chevy listings for all years to 66-87 and none listed usage of the 2500# spindle/bearing. I thot it may be a Big 10 or a 3/4 ton however the 5 lugs rules that out. GMC is the only place I found it.
Can these spindles be used on a 66 Chevy C10 also with same parts as I described above??
thanks
