06-29-2005, 10:42 PM | #1 |
BF Goodrich Radial T/A's
Guys I know I'm getting old asking all of these tire size question but I really want to be sastisfied when I get them so please bear with me.
Does a Bf goodrich radial T/A tire look wider than another brand tire of that same size? It says it has a wide profile look and was wondering if it was acutally wider than a tire of the same size? I've seen pics from you guys of a non lowered truck with the 275/60/15 on all 4, but I'd like to see one (if possible) with the BF Goodrich radial T/A's 275/60/15's If any one has one I'd like to see it, or just tell me what you think. I just dont want it to look stupid if the tires are really wide on the front too. But I really want the Radial T/A's. Sorry for all of the aggravation Jeremy
86 c-10 383 w/ sportsman II heads comp 286h cam Edlbrock RPM Performer intake Holley 750 th350 w/2400 stall 3.73 gears with powertrax No-Slip posi unit. Just broken in good. Will get a 1/4 time this week. |
06-29-2005, 10:54 PM | #2 | |
mine arent 60 series, but they are bfg radial t/a's
these are 285/70/15's....and they fit perfect in the rear ...and make it look "tubbed" Quote:
1987 350 TBI lowered 5/7 |
06-30-2005, 10:04 AM | #3 |
frt r 275/60/15s and the rear r 295/60 /15s there the old style bfgs but the newer style looks atlot cleaner
http://img.photobucket.com/albums/v5...ropped/sig.jpg Last edited by bodydropped; 06-30-2005 at 10:14 AM. |
06-30-2005, 11:01 AM | #4 |
my gas saver
i've got the same bfg tires 245/60's. they are good tires imo.
85' SWB, 4.3/TH350, getting ready for paint 84`SWB, 462ci./TH400, cowl hood, 15" billet spec., flows, blazer buckets/console, flat black 71`SWB, project ebay feedback |
06-30-2005, 11:21 AM | #5 |
'87
The picture in my avatar is when i had some 275/60's. They did look pretty wide on the 10 inch wide wheel.
06-30-2005, 12:03 PM | #6 |
Insert Witty Text Here
I have my second set of 255/70/15 Radial TAs on my truck. The width of the tread on these tires was almost exactly the same as the 275/60/15 Dunlop Elites I was also considering. The Dunlop in the same (255/70/15) size was not nearly as wide as what I had on the truck. I ended up buying a second set because I didn't want something narrower, and I knew these would fit.
So, yes, for a given size, the Radial TAs were wider than the other brands I looked at. I measure tread widths with a tape measure at the tire shop to confirm this. I hope this makes sense.... Slonaker Last edited by Slonaker; 06-30-2005 at 12:04 PM. |
06-30-2005, 05:52 PM | #7 | |
paper or plastic?
1967 Chevy SWB 250 http://67-72chevytrucks.com/vboard/s...d.php?t=442157 1977 Chevy SWB 454 No More 454 getting 5.3 http://67-72chevytrucks.com/vboard/s...d.php?t=310518 1977 Stepside Truck of the month winner http://67-72chevytrucks.com/vboard/s...d.php?t=135524 1965 Chevy C10 454 http://67-72chevytrucks.com/vboard/s...d.php?t=731372 1975 Dodge Power Wagon http://67-72chevytrucks.com/vboard/s...=1#post7871388 |
06-30-2005, 10:18 PM | #8 |
Anybody got a shot of the 285 /70 /15 from the rear of thier truck?
82 C-10 Scottsdale LB owned since 89 350 crate vortec heads Crane 1.6 full rollers edelbrock 1406 edelbrock performer eps intake dynomax headers/flowmaster 70's BTO 700r4 level 3 custom 2 piece driveshaft 12 bolt gov loc w/3.08 |
06-30-2005, 10:33 PM | #9 | |
i will have, before the weekends over
07-01-2005, 01:01 AM | #10 |
Hey bodydropped what type of drop do you have with the use of those 275's up front and 295's on back? That truck is awesome. I was wandering if I just use lowering blocks on the rear would it screw up my ride quality? I was looking at the 4 inch blocks from DJM.
07-01-2005, 09:06 AM | #11 | |
Slonaker Last edited by Slonaker; 07-01-2005 at 09:06 AM. |
07-01-2005, 12:00 PM | #12 |
On the Rocks
My truck has P275/60R15 tires on rear and P245/60R15 on the front, all BF Goodrich Radial T/A's. I can take some better shots if you would like to see how wide and such they look on there. Truck can be seen here: http://67-72chevytrucks.com/vboard/s....php3?t=152862
07-01-2005, 12:38 PM | #13 |
my dads truck is low as u can go he has ladder bars with a panard setup on his and the ft i think he used springs since he built it in 79 they didnt have drop spindles back then
http://img.photobucket.com/albums/v5...ropped/sig.jpg |
07-01-2005, 12:39 PM | #14 |
another close up of the rear tires
07-01-2005, 11:49 PM | #15 |
driving is in my blood
BF's suck big time IMO. I've run them at all 4 corners on my 78 and just the rears on the 79 [only reason was they were used and cheap and I needed tires] I now stay as far away from them as possable. They don't have any traction, and they hardly smoke when used in a burnout of any sort. So to me they aren't good for anything
And to answer your Q, no I don't think they look any different.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
07-02-2005, 09:23 AM | #16 |
I don't particularly like them either. They aren't as bad as they used to be, though. They look nice, but are overpriced. My truck had a new set when I bought it. When it came time to buy tires, I had a choice of them or Dunlop Elites. The Dunlops were smaller, and I would have to changes sizes. I went with these because I already knew they would fite with the drop.
Slonaker |
07-02-2005, 06:48 PM | #17 |
No No
I had BFG Advantage GT 275 60 15's all around IMO they were a very good tire and the slightly lower profile tire set the truck off very well. I had them for 4 years before the front end ate the inner tread off. Now thats it's aligned with all new components up front it has wussy wallmart goodyear wranglers 235 75 15, look's gay now.
I'll dig up a pic and scan it tonight of how it looked with the BFG's on it.
1976 Custom Deluxe SWB Med FMB.3/4 Drop. Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out. 1997 K1500 ext cab 5.7 stock except muffler |
07-02-2005, 06:56 PM | #18 | |
"wussy wallmart goodyear wranglers 235 75 15, look's gay now. " man, that cracked me up....lol
07-05-2005, 03:58 AM | #19 |
295's rear 245 up front. They look cool to me
