06-30-2005, 01:40 PM | #1 |
tire size?
I had put this in the wrong forum. So here it is in here,
What size tire are people using for this set-up. ART UCA and LCA with bags and 2 inch drop spindles. I lowered my truck to the ground yesterday and the tire was hitting the cut out potion of the fender well. i have 205/70/15 on it now and looks like maybe I have to go to a lower profile. Any suggestions?
2014 GMC Yukon XL (Wifey's) 2004 Chevy Silverado Crew Cab Z71 Last edited by 2low72; 06-30-2005 at 01:40 PM. |
06-30-2005, 07:28 PM | #2 |
I'll probably die a slow gruesome death for this but IMO you shouldn't switch to a shorter tire (too short of one anyway) to gain clearance.
The main reason we lower our trucks is to improve the looks & a tire that's too short detracts from the all the hard work because it looks 'lost' in the wheelwell opening. These trucks need a 26" minimum height tire (27" is better) up front. Your 205/70-15 is 26.29" & already right @ the edge of that minimum height. Cut the top of that inner fenderwell for clearance or don't go as low. What good is having the clearance to have it slammed if it looks goofy the rest of the time your driving it? Anyhoo . . .... this is just my perspective.
07-01-2005, 08:48 AM | #3 | |
07-01-2005, 12:47 PM | #4 |
Stock sizing was about 28.5" tall so I like to keep it @ 28" minimum up to about 31".
In a perfect world, 27.5" up front; 28 ~ 29" on the rear.
07-01-2005, 01:33 PM | #5 | |
07-01-2005, 08:53 PM | #6 |
I just got 255/60's that are 27.1" tall on Van rallys on the front and 275 60's 28" tall for the back on 8" rallys. I would not want to see any shorter of a tire in there. I am not on Air but the tire sizes look killler. Either cut for clearance or dont go as low. IMO
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
07-01-2005, 08:54 PM | #7 |
Should add I have about a 4/6 drop
07-06-2005, 01:22 AM | #8 | |
Hay Team!!
1972 Chevrolet Cheyenne LWB "Orange and White" 8) |
