06-30-2005, 05:25 PM | #1 |
Drum to disc conversion ?'s
Found a mid-70's for a donor. I plan to swap the entire crossmember. Mine is a 1970 chevy c-10. Can I swap just the axle shafts in the rear, or is the housing different? Can I use the mid-70's booster and master cyl? Or do I need the older unit. I have manual drums now.
I think the world needs a drink... Help somebody...If you can....VanZant We're not wrong, we're not sorry, and its probably gonna happen again. That's the truth about men. Tracy Byrd Member# 13924 '70 c10, 350/350 '68 c10 250/4spd '68 c10 no eng/trans fac ps/pb/ac/at (future father/sons project) '48 Chevy Loadmaster |
06-30-2005, 05:36 PM | #2 |
Keepin an eye out
There are 2 different axel lenghts fo the '70 model year. If you have the longer ones you can swap em straight across.
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
06-30-2005, 08:35 PM | #3 |
Designated A-hole!
The easiest way to do the m/c booster is to get a 71/72 m/c and proportioning valve.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
06-30-2005, 10:41 PM | #4 |
what about a 67 are the axles different? I just bought a 72 donor truck
67 chevy stepside, 6 cylinder, three on the tree, small window. Currently in resto. |
06-30-2005, 11:21 PM | #5 | |
Keepin an eye out
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 Last edited by boraxman; 06-30-2005 at 11:22 PM. |
07-01-2005, 07:21 PM | #6 |
Go with changing out the whole rearend Jamal. Get new u-bolts because your going to destroy the old ones and they are probably shot anyway. I did my 69 recently and I was a bear to get the u-bolts off until I got a compressor and a cut off tool. Like a hot knife thru butter.
1969 chevy C10 long bed 350 4bbl auto p/disc and 5 lug |
07-01-2005, 08:32 PM | #7 |
Have a new set of chrome u bolts so no problem there. The only thing is I don't have the welding skill to weld the new brackets on.
07-01-2005, 09:41 PM | #8 |
Designated A-hole!
As long as they are both the same type of suspension you shouldn't have to move the brackets.
07-02-2005, 10:56 PM | #9 |
67 is coil spring parts truck is leaf
