Old 06-30-2005, 06:39 PM   #1
Jimbotronics
YA YA
Jimbotronics's Avatar
Fire wall - how do I get this crud off...?
Hi all,
Truck has been sitting for the past couple months in my garage as you see it in the first photo. This being a three day weekend I'm hoping to make a little progress.
Now on to my problem, I've tried just about everything I know to try to get this caked on and rubberized crap off the firewall to no avail. Anyone have any suggestions. Second is I purchased high temp prime and baby blue rattle can paint from the parts store, I'm not look for a show truck just a good appearance when I show the engine off. Should the rattle can paint suffice?
Cheers to all - Jim
Jimbo
'72 SWB - 350 (frame-off resto in progress - donations accepted)
'04 Chevy Avalanche
'03 Cadillac CTS (wife's ride)
Restoration progress - http://67-72chevytrucks.com/vboard/s...d.php?t=335707
Jimbotronics is offline   Reply With Quote
Old 06-30-2005, 06:54 PM   #2
shifty
Questionable
shifty's Avatar
Torch + putty knife.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 06-30-2005, 06:56 PM   #3
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Get one of thoes lil hand held bottle deals
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Big Piggy: "Goliath" 07 Kodiak C4500
Lil Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 06-30-2005, 07:03 PM   #4
cdowns
cdowns's Avatar
www.eastwood.com has a product called underoff for removing undercoating , also chech local body shop supplier for similar products
Old 06-30-2005, 07:10 PM   #5
Jimbotronics
YA YA
I'll check that out Cliff - I also have the mini tourch and will try that too!
Thanks fellas!
Jimbo
'04 Chevy Avalanche
Old 06-30-2005, 07:21 PM   #6
shelby987
shelby987's Avatar
Way back when I got my first car, I used s.o.s pads and elbow grease, it worked really well. I have also had luck using soft scrub and a plastic sponge (not sure what they are called, but its the one that kinda looks like the steel wool that sos pads are made of). I have also been told that diesel fuel and rags will work, but I have yet to try that......bug and tar remover may work in a pinch....as of yet, I have also not tried that either.
p.s. the s.o.s pads didn't hurt my paint at all, you just need to stop scrubbing so hard when you hit paint
shelby987 is offline   Reply With Quote
Old 06-30-2005, 07:26 PM   #7
shelby987
shelby987's Avatar
p.p.s
The same car was definately painted with a spray paint can....and I was quite pleased with the end result. If you are at all used to sparying paint with a paint gun, go down to home depot and pick up a handle attachment that clips to the top of the spray paint can, makes the paint much easier to put down evenly IMHO. If you want something that will match a little better and dont have access to an air compressor and a gun, home depot also sells these make shift spray paint cans that have a compresssed air tube in them, you could match the paint as best you can with krylon and get a pretty good finish (have used this method on a 55 chevy....big can white, little can brown.....eggshell matched the bed sides really well....just make sure you thin it out and paint in multiple coats).....yes, I am a backyard body work guy....(read: cheap)......whatever works!
Old 06-30-2005, 07:36 PM   #8
Jimbotronics
YA YA
Thanks Shelby - I've used just about every kind of degreaser and wool brush method know to man to include this stuff a friend gave me that melted latex gloves. I just ran out and tested a small spot with the mini-torch, seems like it's gonna do a pretty decent job. Though I don't want to remove all the electrical wires and such so getting very close to them is going to be a little tougher. I have one of the rattle can triggers that you're talking about and will definitely use it. Thanks for reminding me about it...
Jimbo
'04 Chevy Avalanche
Old 06-30-2005, 09:38 PM   #9
1972ChevyCheyenne
If you trust yourself using sharp objects get a razor blade, the type that the body guys use and scrape it off. I did most of the firewall this way.
Jamie
1972ChevyCheyenne is offline   Reply With Quote
Old 06-30-2005, 10:34 PM   #10
Green Machine
Green Machine's Avatar
Mineral spirits will soften undercoating, put some in a spray bottle and soak it up several times. Or try some WD40. Once it is softened, I would get a pressure washer and blast the gunk off. Just don't use the torch method with the mineral spirits !!!
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 06-30-2005, 10:37 PM   #11
arkracing
Weekend Warrior
Someone over in the Paint and Body section suggested "Oven Cleaner" a while back on a similar post about getting undercoating off the floors
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
Old 06-30-2005, 10:58 PM   #12
68C15
blood type; Retumbo
68C15's Avatar
brake cleaner & a match. oh wait, you wanna keep the truck. skip the match, just use the brake cleaner & a scraper. then a wire brush.
is the primer self etching? I have seen many engine bays done with rattle cans. it holds up quite well. just doesnt look super nice. but for a DD it will be perfect.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 06-30-2005, 11:49 PM   #13
pjmoreland
pjmoreland's Avatar
If you don't care about the paint, a wire wheel mounted on a hand-held grinder will take that stuff right off in a matter of seconds. Be sure to wear safety goggles though so you don't get flying wires stuck in your eyeballs.
pjmoreland is offline   Reply With Quote
Old 07-01-2005, 12:15 AM   #14
stllookn
Saving 1 truck at a time!
stllookn's Avatar
I have used about everything but find the fastest way now is a heat gun (Harbor Freight $15) and a putty knife. Then use coarse steel wool and mineral sprits to get off the thin black slime that is left. Sometimes just the putty knife will flake it off if it is really old and brittle. Maybe just in the winter...LOL. I used to use a torch but the heat gun is much safer and plenty hot enough to take off even the paint.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 07-01-2005, 03:46 AM   #15
deth_1970
deth_1970's Avatar
I have had good results with Dawn Power disolver, get it a your local grocery store
78 dualy crew cab wife calls "the beast"
79 silverado "yeller"
99 tahoe
02 Gmc sierra
deth_1970 is offline   Reply With Quote
Old 07-01-2005, 04:48 AM   #16
tomatocity
tomatocity's Avatar
http://www.eastwood.com/shopping/pro...ercoat+remover
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck.
tomatocity is offline   Reply With Quote
Old 07-01-2005, 07:36 AM   #17
mrein3
mrein3's Avatar
I used laquer thinner and a rag when I was doing my non-AC to AC conversion. I had the fender and inner wheel well out of the way so I had VERY good access on that side. The paint that was protected under there looked real good when I was done.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 07-01-2005, 08:56 AM   #18
Don Brace
Active Member
I used a Windex spray bottle filled with kerosene. Spray the kerosene on and let it soak for about ten minutes. Then scaped it off with a putty knief. Washed it with Dawn dish detergent and then used a wire brush in the drill. Cleaned it all off.
Don in Mn
Don Brace
55 Nomad
56 Nomad
58 Impalla Coupe
58 Bel-Aire 4D HT
61 Impala CVRT 409 4 SP
2- 71 Longhorns
Always looking for old toy trains, Juke boxes Pin ball and game machines.
Don Brace is offline   Reply With Quote
Old 07-01-2005, 10:10 AM   #19
TruckinDaddy
What's that funky smell?
TruckinDaddy's Avatar
I got oven cleaner on the firewall when I was deegreasing the engine. Cleaned the it up nicely, so I did the entire firewall. I made sure I rinsed it off in just a couple of minutes. Still, it removed the paint in one small area by the trans linkages.
Mike S
68 C10 Long Step (Pretending to be a Long Fleetside) Grandpa's Farm Truck
3 on the tree, 307, No power brakes or steering
Factory Options - HD rear spring and Ammeter/Oil Gauges
My truck blog
My Car Domain page
TruckinDaddy is offline   Reply With Quote
Old 07-01-2005, 03:40 PM   #20
mocwon
Keep On Truckin'
mocwon's Avatar
3M Clean and Strip Wheels
Norton makes something similar too. These are also very good for removing rust, bondo, paint and finger if you're not careful...
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
