06-30-2005, 08:52 PM | #1 |
Questions about 68-72 / 73+ Leaf Springs
I have a 72 C20 that was converted to a 4wd. They used 73+ differentials. I'm trying to determine what springs I need and if I can just buy a standard 6" lift from Skyjacker for a 67-72.
My rear springs are 52" from eye to eye and are 2.5" wide. The front springs are about ~47" long eye to eye and are 3" wide. Is this correct for my year truck?
- '72 Chevy C20 4x4 LWB Fleetside, 350/SM465, NP205, '73+ Axles (D44/14B FF 8-lug), 4 Wheel Discs - Updated Pics |
07-01-2005, 06:41 AM | #2 |
user # 2756
rear would be the same 69 and up except for the rare 56" spring on high gross weight vehicles.
For the front sounds like you have 73 and up springs. You'll notice they are 3" wide at the ends and 2.5" wide in the middle. All lift springs I've seen are 2.5" wide and make up the differnece with wider bushings at each end(1/2" v. 1/4" sticking out). Also dana44HD is a 3/4 ton.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm |
07-01-2005, 01:12 PM | #3 |
So what is the proper spring sizes for a 72 K20 from the factory?
07-01-2005, 01:38 PM | #4 |
Certified Chevy Man
The front springs on a 72 should be ~44" long eye to eye.
68 Chevy CST (327,TH400) 3/5 drop lots of fun stuff 71 Suburban 4x4 (350,TH350) 7" lift 37's, D44/14 bolt and other sorts of goodies, lockers front and rear, flexes 40", 895 RTI score Check out my web site!!! http://www.geocities.com/cst68chevy/ |
07-01-2005, 01:50 PM | #5 |
I'll have to measure again. Are the 73+ stock springs longer? I apologize for the dumb questions, but I'm having to try and figure out what the previous owner(s) did to this truck.
07-01-2005, 02:18 PM | #6 |
Certified Chevy Man
73+ should be ~47" front springs eye to eye.
07-01-2005, 02:21 PM | #7 |
So then I should just go with a 73+ lift kit if I don't want to move the front spring mounts?
07-01-2005, 04:51 PM | #8 |
MEasure the distance you have between the front spring mounts and the rear of the spring shackle to determine what length you need. It all depends on whoever converted your rig to 4x4, where they mounted the hangers. Measure to know this distance before you buy springs.
Ken '60 GMC 3/4T 4x4 '60 GMC Suburban 4x4 '64 GMC Suburban 4x4 |
07-01-2005, 08:47 PM | #9 |
I've got 52x2.5" in the rear, 47x2.75" in the front. I just measured it again. The front springs do not taper down to 2.5" - they are more like 2.75-2.85" all the way through. All I need to know is are the 73+ rear springs 2.5" wide? If so, then I should have no problems ordering a 73+ lift kit.
Thanks for the help guys.
07-02-2005, 06:56 AM | #10 |
user # 2756
Yes
