06-30-2005, 10:25 PM | #1 |
Heat Stove for small block
WTB Heat Stove for small block. Does not have to be in good condition.
68 Short Stepside, 350, quadrajet, 700r4, 3:73 posi, power front discs, HEI, Factory Air, Tilt, Tach, accelerator cable instead of rod, sway bar. 96 Impala SS 97 Monte Carlo |
07-01-2005, 02:29 AM | #2 |
I have one but shipping might not be worth it? If you can't find anything closer PM me...I was just going to toss this stuff out.
"You can take the man out of PA, but you can't take PA out of the man" |
07-01-2005, 08:25 AM | #3 |
I just bought one but it turned out to be for a 2wd. I need 4x4. What are you looking for?
72 3/4 4x4 350 4spd 72 3/4 4x4 350 auto 2004 Duramax Silverado 4x4 2006 Duramax Crew cab 4x4 2010 Harley Ultra Limited 2011 Harley Street Glide |
07-01-2005, 02:16 PM | #4 |
I thought that 2 and 4 wheel drive ones were the same ???
07-01-2005, 02:59 PM | #5 |
So what is the difference in the 2wd and 4x4 heat stove?
1978 Dodge Omni |
07-01-2005, 03:11 PM | #6 |
2wd is made for the angled ramshorn and the 4wd is made for the straight.
07-01-2005, 03:23 PM | #7 |
I just bought one from Randy that is supposed to be for a 2wd that is straight. Do you have pictures of the 4x4 one?
Todd
1978 Dodge Omni |
07-01-2005, 10:47 PM | #8 |
nu2-72, I am looking for 2WD, how much for your's?
07-03-2005, 09:59 AM | #9 |
Here is what the GM book shows
68 CK-10,20 w/at 69 CG-10,20 w/at 69 K-10 Blazer w/at 70 CKG-10 (8 cyl.) 70 CK-20 (8 cyl.) 70 C-30 (8 cyl.) 71 CK-10,20,30 (396) 3982954 cover, carb air heat stove 71-72 Ser. 20,30 (D.D.)(8 cyl.) 3976258 cover, carb air heat stove 72 Ser. 10 thru 30, Blazer (307, 350) (exc. NB2, D.D.) 3993363 cover, air heat stove This does not show any difference from 2wd and 4x4. I will head to the shop today for a little research. The D.D. means double-duti, Forward control chassis and the NB2 is N.O.X. emission control (Cali. only) I have spoken with restorers and been told that there was a difference between big block and small, 2wd and 4wd and emmision and non. Let me look a little closer today and see what I find.
07-05-2005, 06:42 AM | #10 |
Well after some digging around, I can find no differences. Compared the one I just got with my 4x4 and it appears to be the same. Also the GM book shows no difference. It does however show some alternate sources. Looks like vans are good for several things. Big block are different and so is the Calif. model.
Guess I am corrected. Hope this helps someone in their search.
07-05-2005, 09:13 PM | #11 |
HeavyD, you have a PM
07-06-2005, 11:36 AM | #12 |
Sorry for the delay Don. I was relying on hearsay and needed to do some checking myself. Guess i will be keeping the one I have. Hope you find one.
I would think the guys in the better climates could find some of these on vans. I always see someone looking for them. Good luck.
