06-30-2005, 10:37 PM | #1 |
wire amps ect
howdy do
i just got a great wiring diagram but now i need to know what amps each circuit is( head lights, taillights, blinkers, ect) now i know somebody has knows in here or mabe a link. |
06-30-2005, 11:55 PM | #2 |
Usually the wiring diagrams will say the gauge of the wires right in front of the color. You could probably find a chart somewhere in the internet that shows how much current a given wire size can carry. Make sure you look for stranded wire ratings, not solid wire.
07-01-2005, 12:34 AM | #3 |
huh ???
This is the fuse ratings from a pic of the fuse box.
panel lamps 3 amps cluster feed 3 amps glove box & spot lamps 15 amps back up lamps 10 amps tail & stop lamps 20 amps heat 3 amps traffic 15 amps a/c 10 amps I can't make out the one for wipers but it looks like at least a 20 amp fuse... Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
