Old 07-01-2005, 12:59 AM   #1
brad juan
what gas tank to use besides the blazer tank
has anyone installed a out of the bad gas tank besides the blazer tank? I have a blazer tank but I'm not sure I want to use it, I'm not sure what to do with the fill on it. I dont really want to put it behind the marker light. I was just wondering if there is any other tanks out there that people have used, also how easy was it to hook up the fill on it. My other question is if I do install my blazer tank, am I going to be to low and dragging it on curbs, I am lowered 3.5 and 5.5, thanks for your time.
1972 chevy C/10, with factory air, SWB, 350,700r4, lowered 3 and 5.
brad juan is offline   Reply With Quote
Old 07-01-2005, 01:44 AM   #2
tomatocity
tomatocity's Avatar
I heard something about a Jeep tank but I don't know whick tank.
Do you have rear leafs? I was trying to figure how you got 5.5 with coils. Do you have pics of your truck. I would like to see how it sits. I am thinking of doing the same drop.
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck.
tomatocity is offline   Reply With Quote
Old 07-01-2005, 07:05 AM   #3
Joe67
67 is sold
Here is a long thread with a few options
http://67-72chevytrucks.com/vboard/s....php3?t=117123
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 07-01-2005, 08:46 AM   #4
see ten
WTB this ad
see ten's Avatar
I used a jeep CJ tank on a 66 that I used to have. It fit right in between the framerails. I don't really know if this is any better than the blazer option. The sending unit for the jeep tank made my gas gauge work backwards! When I sold it I told the new owner that E means enough and F means that you are.... well you get the point.
see ten is offline   Reply With Quote
Old 07-01-2005, 03:15 PM   #5
mocwon
Keep On Truckin'
mocwon's Avatar
I got one from Fuel Cell Guy (Mark Fowler, board member). Welded fuel door assembly in from a 1990 Maza 626 and fabricated bed side filler neck cover. Haven't hooked up the filler pipe yet but it shouldn't be a big deal.
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
Old 07-01-2005, 06:25 PM   #6
modifiedGMC
I used a tank off a 70's Chevy Luv pickup. It mounted without straps, it was bolted to two brackets on the frame. The one in the picture was shortened two inches (top to bottom) and welded back together. I used the original in cab sending unit but had to modify it to fit the new rear tank depth. The down side of mine being shortened is now it's only about 8 1/2 to 9 gallons which means more stops at the gas station. I should have not shortened it and just moved it farther up into the frame. I cut two pieces of angle, bolted them to the tank and got it in place where I wanted it and welded the angles (see red arrows) to the bottom of the frame while it still had not had gas put in it yet. I think I may go back and put a bigger one in it's place later on. For now it works good because I don't drive it that far.
If it don't fit, force it,...If it still don't fit , modify it 'till it does fit !!!
modifiedGMC is offline   Reply With Quote
Old 07-01-2005, 07:27 PM   #7
Bob Moore
ModifiedGMC - What about the filler tube? Does it go out the back or to which side?
Thanks for another option - Bob
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 07-01-2005, 07:37 PM   #8
Rokcrln
Rokcrln's Avatar
I had one made by Fat Fender Street Rods that is a work of art and has a intank pump to run my 93 vett LT1. Made out of SS and it is about 35gals. The filler is out the drivers side and it will get a small door like MocWon's above (looks good).
Kevin
Rokcrln is offline   Reply With Quote
Old 07-01-2005, 10:04 PM   #9
Joe67
67 is sold
Nice work on the fuel filler mod
Old 07-01-2005, 11:01 PM   #10
modifiedGMC
The tube comes out the back of the tank and runs over to the driverside marker light. I had to cut some of the bed out and make a cover for it.
