Old 07-01-2005, 03:16 PM   #1
TP from Cntl PA
TP from Cntl PA's Avatar
Man, are the new GM Buckets nice in the '71
Finally got the '00 Buckets and center section in my '71 C-20 project. I originally planned to wait until the body work was done to install them, but decided to put them in now. It sure makes it a nice comfortable truck to drive now!
The only bad part is we've been helping my neighbors irrigate their tomattoe crop and the nice seats are covered in dried mud...........We lost our rented ground last year, so we no longer farm, but I guess once a farm truck, it'll always be a farm truck!
We've been moving hard line and irrigation pumps with it and the Cummins is running great!..............It's probably the only pickup in my area covered with mud. We sure need the rain bad!
If anyone is looking at newer GM buckets to put in their ride, I highly recommend them!
'72 K-20 EFI'ed 250 Inline/4spd stake body, Farm Truck
'71 C-20 Cummins Diesel Powered, In storage thanks to $5.00 diesel!
'69 3500 GMC 305V-6/4spd, Still under reconstruction..........
Inlines Rule! 6 soldiers standing is better than 8 laying down!!!!!!!!
TP from Cntl PA is offline   Reply With Quote
Old 07-01-2005, 03:20 PM   #2
mocwon
Keep On Truckin'
mocwon's Avatar
The late model seats look real nice and are much more comfortable. I tested some later model seats like that but they shoved me way too close to the steering wheel. At 6'4" and 235# I need a little more room than the new seats afford.
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
Old 07-01-2005, 03:25 PM   #3
TP from Cntl PA
I am 6'1" and break in on the scales a 215..........My brother is 6'3" and we don't seem to have any trouble. I was initially concerned at first about it as it looked alittle close, but after using it they are just right. A tilt wheel column and a smaller steering wheel would solve any problems IMO.
Old 07-01-2005, 11:43 PM   #4
5150
C10 Club Tennessee
5150's Avatar
Looks great!
I have those exact seats, but have not installed them yet. Do you have any more pics of the seats or of the install. They would me most helpful.
thanks,
Bryan
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 07-02-2005, 09:24 AM   #5
vtblazer
vtblazer's Avatar
I feel your RELIEF.
Have those in my 72 daily driver, know exactly what your saying.
vtblazer is offline   Reply With Quote
Old 07-02-2005, 09:25 AM   #6
Joe67
67 is sold
Seats look good in there. Do you still have the factory tank?
Were you able to use the '00 brackets and bolt them right in or was there some fab work required?
Thanks.
Joe
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 07-02-2005, 09:35 AM   #7
TP from Cntl PA
We just drilled holes in the floor for the buckets after moving the sliding track ahead some..........Works well, but be aware that you'll have to put plates on both the top and underside of the floor so they don't eventually bounce through the floor, or pull up through. The center piece took some modification, but basically we just torched off the OEM mounting tabs, and relocated them in the front, and I took a piece of flat stock and ran it across the factory bracket in the rear. I mounted it down lower than the other two so I could throw my ledgers and other junk and not have it slide all over.
Yes, the fuel tank is still behind them too.
Old 07-02-2005, 09:47 AM   #8
Joe67
67 is sold
