Old 07-01-2005, 05:29 PM   #1
nevada70chev
help with sealer/primer...???
i just got a truck and the PO has in down to metal, no surface rust, it been inside. i just want to know what can i use as a sealer primer to protect from rust, but still be able to do body work without having to remove what i put on. thanks.
70 LWB, 350/350 A/C, P/S, 3 Tone Paint (white cap, primer gray with black guide coat)
nevada70chev is offline   Reply With Quote
Old 07-02-2005, 12:42 AM   #2
OhioChevy
If the metal is good and clean then spray it with etching primer.
OhioChevy is offline   Reply With Quote
Old 07-06-2005, 03:57 PM   #3
shifty
Questionable
shifty's Avatar
Eastwood Rust Encapsulator. www.eastwood.com
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
