Old 06-21-2002, 01:04 AM   #1
WORNBRAKES
Question Please help fast
middle of HEI conversion. Is this right? remove old crap, drop in hei, take power that went to coil and put to pat plug on hei, and then connect wires. Done all this and truck wont start. turns over and it has spark(ouch) but wont start. I am moving distrib to try to find the timing and i cant get it. I read on a old thread about changing gap of plugs to .045. Is that my problem?
Thanks,
Mario
Mario and Mandy
Hughesville, MD 20637
69 C10 305/350
71 K5 Basket case
75 K10 Rescue **Parting out**
77 MG Midget **Parting out**
15 6.7L Cummins
WORNBRAKES is offline   Reply With Quote
Old 06-21-2002, 01:07 AM   #2
Mitzki5
"TRUCKLESS"
Mitzki5's Avatar
I am not a wiz at this but do you #1 cylinder at TDC and rotor pointing to #1? I think that's what you want. Only helped do this a couple times.
You also might have dist 180 degrees off.
Mitzki5
No longer have an old truck! But always looking for another one!
Mitzki5 is offline   Reply With Quote
Old 06-21-2002, 01:10 AM   #3
COBALT
COBALT's Avatar
Hopefully you kept track of where your plugs were in the dist. cap. From what I remember reading what used to be the #1 plug is now the #2 plug. You have to move what was the #1 plug one spot CCW...
I'm probably wrong...
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 06-21-2002, 01:11 AM   #4
WORNBRAKES
I was at TDC when I replaced it. I have done it 180 before and I learned my leason. I am curious about the gap of plugs and if I am missing something with wires.
Mario and Mandy
69 C10 305/350
71 K5 Basket case
15 6.7L Cummins
Old 06-21-2002, 01:13 AM   #5
Mitzki5
"TRUCKLESS"
Mitzki5's Avatar
Try going into chat. I haven't been in there tonight but am sure someone can talk you thru it. They helped a guy a while back with same problem.
Mitzki5
Old 06-21-2002, 01:15 AM   #6
Super Chevy
Super Chevy's Avatar
make sure you have a full 12volts to the HEI,the old points only ran 8volts,it was regulated,run a hot wire from the fusebox "key on hot" to the HEI....
SC
Super Chevy is offline   Reply With Quote
Old 06-21-2002, 01:22 AM   #7
WORNBRAKES
I will try a new wire. Anyone know about the gap. Where is the chat? Never done that. brb
Mario and Mandy
69 C10 305/350
71 K5 Basket case
15 6.7L Cummins
Old 06-21-2002, 01:30 AM   #8
Alexis
Member since 2000
Alexis's Avatar
http://www.67-72chevytrucks.com/chat.html
Alexis is offline   Reply With Quote
Old 06-21-2002, 01:40 AM   #9
Paul Clark
If you have spark, do you have fuel?
Spark and fuel should do "something". Spark without fuel won't do anything.
Paul Clark is offline   Reply With Quote
Old 06-21-2002, 01:44 AM   #10
WORNBRAKES
Paul- see no reason not to have fuel. I didn't touch that.
alex- can't get the chat room to open.
What gap are you guys or gals running on a small block with HEI?
Mario and Mandy
69 C10 305/350
71 K5 Basket case
15 6.7L Cummins
Old 06-21-2002, 01:45 AM   #11
Alexis
Member since 2000
Alexis's Avatar
what browser are you running. you need to let it load up. there a link at the top of the page once you click on that link that should work
Old 06-21-2002, 01:46 AM   #12
Paul Clark
Forgot to add -
If you have spark, the gap on the plugs and the wires are not the problem. Something should be happening. Backfires, etc.? - but pretty sure something should be going on.
Good luck.
Old 06-21-2002, 01:46 AM   #13
WORNBRAKES
SC- I just tried running a hot wire fron both the radio plug and the heater plug and it was the same. I believe those are 12V.
Mario and Mandy
69 C10 305/350
71 K5 Basket case
15 6.7L Cummins
Old 06-21-2002, 01:49 AM   #14
WORNBRAKES
Paul-- I am going to go look at the carb and fuel lines right now. Is there something specific you might recommend?
Mario and Mandy
69 C10 305/350
71 K5 Basket case
15 6.7L Cummins
Old 06-21-2002, 02:02 AM   #15
Patrick Sullivan
Transcendental Trucker
Patrick Sullivan's Avatar
You had it at TDC.. are you sure it was on the compression stroke?
Patrick Sullivan | sullivan@oregoncoast.com
Rockaway Beach, Oregon
1972 Chevy Cheyenne C-20
1998 Dodge Dakota 4x4
So, fill to me the parting glass
And drink a health whate'er befalls...
Then gently rise and softly call
Goodnight and joy be to you all!
Patrick Sullivan is offline   Reply With Quote
Old 06-21-2002, 02:10 AM   #16
Super Chevy
you got good plugs in it? and did the HEI work when it was pulled from another viehical, does it want to start or just flat out nothing?
Old 06-21-2002, 02:16 AM   #17
WORNBRAKES
I am getting pleanty of fuel! What ever it is I guess it will have to wait until tomarow. I live in a townhouse and I don't think the neigbors like me trying to start the truck this late! B/c if I got it started then it would take a few to set the timing. I don't beleive in a quiet exhaust. lol I have had the HEI sitting for over a year now and finaly Glen at Parts Plus said the magic words." BETTER GASS MILEAGE" With the move to Flordia next month I can use that! So I bought a new cap, rotor, and coil for the bastatd and figured it would take a few hours. Now I have to take the wifes truck to work in the am. But that aint so bad b/c now I get to leave work at 10 to take her to work and the boy to school. THAT IS GREAT. I also bought a Tach tonight and will install that when I get her running.
I have one for you guys. I run a '68 3/4, 4.10 rear, th350 and a '69 327 from a Camero that was built custom for top end. I know it is missmatched, but that is another story! Is there any thing that I can do( cheapley) to help me in the 3000 mile journey across the country? I will be towing a trailer of crap I made out of my 1/2 to parts truck. I know the best thing would be to get either a overdrive trany or some higher gears, but that is a little spendy! What do you think?
Mario and Mandy
69 C10 305/350
71 K5 Basket case
15 6.7L Cummins
Old 06-21-2002, 02:18 AM   #18
Paul Clark
I ain't no guru on anything, but here's what I would check. I might be full of beans, but -
You DO have spark, right?
Then you need fuel. Assuming you have a carb. Look down it and pump the accelerator. Do you get gas spraying? If so, like I said before, "something" should happen. (like getting your eyebrows burnt off from a backfire)
If nothing happens, rotate the cap and keep trying.
Another idea -
Do you have an older Holley carb? If so, if it ever backfired, you might have blown the power valve.
It won't start.
Just ideas to check. Someone with a lot more knowledge than I can probably help you out. Hope so. If you still can't make it go, let me know. I'll ask some of my smart friends.
Good luck
Old 06-21-2002, 02:20 AM   #19
WORNBRAKES
I am on the comp stroke. the plugs are fine I just am curious about the gap? I pulled the dis out of my parts truck and it worked great there. Thanks guys!
Mario and Mandy
69 C10 305/350
71 K5 Basket case
15 6.7L Cummins
Old 06-21-2002, 02:30 AM   #20
Patrick Sullivan
The gap is usually at .045 for HEI, but it should run even on the stock points gap.
Old 06-21-2002, 02:31 AM   #21
WORNBRAKES
I know I have spark b/c the wife turned the key and I got shocked! She then found the tach on the seat and was unhappy. lol Thats to bad. I use a q-jet and I watched the fuel flow in. I am going to start from square one tomarow and hope that I missed somethiing stupid. If all else fails, I actuly like the points system.
Mario and Mandy
69 C10 305/350
71 K5 Basket case
15 6.7L Cummins
Old 06-21-2002, 02:31 AM   #22
Super Chevy
.045 was stock for HEI ,some were .050 ,you should be safe with .045 though
Old 06-21-2002, 02:34 AM   #23
WORNBRAKES
Thanks!!! You guys have been great!
Mario and Mandy
69 C10 305/350
71 K5 Basket case
15 6.7L Cummins
Old 06-21-2002, 02:35 AM   #24
Paul Clark
Educate me here (yet again)
.45 - .50 gap on what plug?
Old 06-21-2002, 02:36 AM   #25
WORNBRAKES
It looks like the three of us might hit 100 posts tonight!
Mario and Mandy
69 C10 305/350
71 K5 Basket case
15 6.7L Cummins
