Old 06-21-2002, 01:51 AM   #1
Paul Clark
Door locks
Got 3 doors. Locks won't move on any of them (I mean the pull up, push down stuff and not the key)
How come?
Rods bent or something?
Paul Clark is offline   Reply With Quote
Old 06-21-2002, 02:07 AM   #2
oleblue72
No, U Da Man!
oleblue72's Avatar
prally gonna have to remove the inside door panels and ck and see what's up. I know when I bought my truck, my pass. side would not move and neither would lock. Still not a lot of room to work in there, but the mechanics are pretty simple and everything needed some lubrication. Good Luck
(sold ole blue 1972)
1997 Dodge 1500 5.9L
1996 Saturn SL2 1.9L
2002 Mitsubishi Montero 3.0L
2005 Ford Escape 3.0L
1967 Olds Vista Cruiser 330-320HP
oleblue72 is offline   Reply With Quote
Old 06-21-2002, 02:16 AM   #3
Bill72BB
Thats the Hillbilly way
Bill72BB's Avatar
i"m with oldblue ,
Pull the panels WD 40 the hell out of the moving part .
BILL
Torrance Calif 90504
Member DUF Club
Member Old Farts Club
72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts
tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion.
" If I knew I was going to live this long I would have taken better care of myself "
Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER....
Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen ,
Bill72BB is offline   Reply With Quote
Old 06-21-2002, 02:30 AM   #4
Paul Clark
"W"ild "D"og 40 will fly tomorrow!
Thanks guys.
Old 06-21-2002, 07:24 AM   #5
Blazer1970
Blazer1970's Avatar
Don't use WD40 if you want them to keep working. It will free them up, but they will rust worse than ever within a few months. Get a spray can of the white moly grease. You can get it at any auto parts store. WD40 sucks.
Blazer1970 is offline   Reply With Quote
Old 06-21-2002, 08:33 AM   #6
JimKshortstep4x4
Smile
This is what I would try first. If you roll the windows down, you can get the small tube of a penetrating fluid in the opening above the latch and spray it. Try to miss the window felt. If it is a sticking problem, this will usually work. I pretty well soak it down with Aero-kroil when I run into this problem. If you can't get the locks to work this way, it usually means that the latch has to be replaced because of wear in the mechanism.
Jim
