07-02-2005, 11:26 AM | #1 |
any body tried this? (r12 replacements)
http://63.135.115.175/products_refr.html
or this: www.duracool.com ? any luck with either? or what other options do you prefer? |
07-02-2005, 02:38 PM | #2 |
67-72 Addict!
Never heard of those. I'm well stocked with 134A and R-12 for awhile.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
07-02-2005, 08:36 PM | #3 |
Never used thoses, but I've been using "Freeze 12" as a drop in replacement in the state vehicles that I maintain for a couple of years now, and have had no problems at all.
Wynne 70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s. Build thread 53 Chevy shortbed 69 Camaro Click here to subscribe Chevy GMC International Truck Club Louisiana Charter Member http://www.louisianaclassictruckclub.com |
07-02-2005, 10:29 PM | #4 |
He's got mean nasty FANGS!
Freeze 12 is the best r12 replacement I've found and used, it cools about like 134a, but is more friendly to an R12 system... Never heard of the others.
2004 K2500 Burb 1999 C3500 1985 Cutlass Supreme 1969 C-10 1967 C-10 Panel josh@67-72chevytrucks.com |
07-04-2005, 01:20 AM | #5 |
ttt
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. |
07-04-2005, 07:01 AM | #6 |
I use this stuff called "Autofrost" in my '72. It works very well in an R12 system. Cools the air at the vents down to 40° F. I bought a 25# Bottle about 3-years ago. The truck leaks a bit and I have to add a pound or two every year. I'll probably buy another bottle next spring.
Good Luck! T |
07-06-2005, 01:33 PM | #7 |
Lovin' Life in Miss.!
The info on the duracool sire alludes to R134 eventually ending up on the chopping block with R-12. Instead of ozone depletion the hazard is supposed to be global warming.
I don't consider myself to be the tree-hugging type but I do try to keep my hazmat down to a minimum. This stuff is supposed to be 30 odd percent more effiecient than R134 and about the same performance as R-12. Price is a lil more expensive than R-134. All that said, I'm interested. I have nearly all of my a/c bits and pieces together. I just need some hoses custom made and a few lines bent up. Hopefully, I'll have it up and going before winter hits. It's a money thing ya know. Still on the fence for the refrigerant. If I use something other than 12 or 134 I'll post my results. Don;t hold your breath though, winter is a few months away. If anyone does have experiance with the hydrocarbon refrigerants, I too would like to know about it. Edit: Newin72, thanks for the heads-up. I would have never found this info otherwise.
The truck... you hear that? No really, you did hear that?!!! Last edited by chickenwing; 07-06-2005 at 01:36 PM. |
07-06-2005, 03:21 PM | #8 | |
07-06-2005, 04:33 PM | #9 |
Gene, did you pull a GOOD vacuum on your system first?
07-06-2005, 05:28 PM | #10 |
Yes, he pulled a vaccum and it held at 22 psi for over an hour.
