needin' money
springs or spindles
is the ride from new lowering coil springs really that bad, compared to spindles
SWB Stands for Short Wide Bed |
Mad Scientist
2" springs seemed fine to me. Didn't even notice the difference in the ride. The handling was better though. Buy good shocks though. Never had any spindles. Seems like a good choice since nothing else changes.
![]() 86 1/2ton on tons! sbc/465/208/D60/14/35's 81 Postal....with 468 bbc 97 Merc Marq comuter 07 Suburban 02 Danger Ranger |
needin' money
anyone else
I just did a 2/4 spring drop.
one problem I am running into that you should consider is that I am only about 3/4 inch from the bumpstops and it bottoms out easy... |
AttentionDeficitDisorder
if you get the correct springs for your vehicle ride quality shouldnt have to suffer, its just the geometry of the suspension that you alter with springs as compared to spindles.
#6 | |
If it don't fit, force it,...If it still don't fit , modify it 'till it does fit !!! ![]() ![]() |
![]() Join Date: Apr 2004
I've had both separately on different trucks and would only use spindles if I only needed a small drop. I use both because I like it a little lower.
KEEP ON TRUCKIN'
![]() Join Date: Jun 2005
I did a 4/5 drop on my truck. 2" drop spindles and 2"drop springs on the front and 5" drop springs on the back. The front geometry is less stressed when you use the spindles. I now have this truck in pieces doing a frame off which will include a 4-way air bag system.
JIM '97 GMC Sierra K1500 '95 Chevy Silverado C1500 '71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 ![]() http://www.youtube.com/watch?v=4l689JKXPnA http://67-72chevytrucks.com/vboard/payments.php "LIVIN' FREE FOREVER" ![]() |
Keepin an eye out
I have 3-5 spring drop, the ride is a little harsh but managable.
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
