Old 07-02-2005, 01:09 PM   #1
RJ100
Engine Swap
I'm new to this board ,been here about a week. I enjoy everyone's questions and comments and gereat pictures. I have a question. I have a stock 1969 C-20 long bed. It now has a 307 with 4 speed granny trans. I have a bum leg and clutching is sometimes difficult. I also have a 283 with a two speed powerglide transmission attached. Would this be a difficult swap? And would it be a good swap?
RJ100 is offline   Reply With Quote
Old 07-02-2005, 01:43 PM   #2
Green Machine
Green Machine's Avatar
IMHO a Powerglides best application is for drag racing only, not street. Get a turbo 350, or 400, but best especially for a low geared C20 would be a 700R4 with the overdrive. Your will need to remove the manual cross member under the bellhousing and add an auto xmember under rear or trans. Starter nose will need to be changed to auto type, driveshaft will need to be changed or altered to fit, cooler lines, different radiator for cooler, and throttle cable/kickdown hooked up and vacumn line ran depending on trans type. Auto shift column, and linkage should be swapped in, backup lights and neutral safety switch rewired, correct brake pedal, remove cluth pedal etc.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 07-02-2005, 02:47 PM   #3
69GMC910
MOTORHEAD!
69GMC910's Avatar
In my opinion, the 283 will be so weak with the glide in a heavy truck. I ran the powerglide behind a 250 horse 350 and it was a major dog. 700r4 would be sweet with the 283 because of the low first gear.
Good Luck!!
910
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Performer RPM Air Gap
Hooker 2455's
TCI Turbo 400 Super Street Fighter
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Hoosier 30x10.5 Radial Slick
Full weight long box pickup
Current best- 11.33@117mph
69GMC910 is offline   Reply With Quote
