Old 06-21-2002, 03:27 AM   #1
jostrans68
Jostrans68
jostrans68's Avatar
Eastwood spot welder
Any one use it for rocker install My body shop friend says its a great unit for this? heres pic.. price not bad
Quote:This tool produces spot welds very similar to those used when your car was built, and joins panels without the need to grind off weld beads. Spot welding is also fast, avoids distortion and confines heat. The spot weld gun attaches easily to your home arc welder set at 60 amps or less; simply connect the spot welder's cord to the electrode holder on your welder, ground as you normally would. Use the trigger to touch the electrode until a molten puddle of metal is formed. Then pull the trigger up to break the arc. Each electrode provides approx. 60-100 welds. Two
[CGTW Member
former 67-72 now with a 96 silverado
jostrans68 is offline   Reply With Quote
Old 06-21-2002, 10:06 AM   #2
slam33
slam33's Avatar
I have one and they do work well. All you need is a small stick welder for power.
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
slam33 is offline   Reply With Quote
Old 06-21-2002, 12:37 PM   #3
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Cool! How much does it sell for?
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 06-21-2002, 01:50 PM   #4
JHickson6
I Love This Stuff!
JHickson6's Avatar
How much and where can I get one??
JHickson6
JHickson6 is offline   Reply With Quote
Old 06-21-2002, 02:03 PM   #5
jostrans68
Jostrans68
jostrans68's Avatar
49.99 I have my Miller buzz box and just ordered on of these cant wait.
[CGTW Member
Old 06-23-2002, 01:02 AM   #6
jostrans68
Jostrans68
jostrans68's Avatar
http://www.eastwoodco.com/cgi-bin/sgsh0101.exe
this link should work its at the eastwoodco.com if it doesnt work go here and search spot welders........mine is on its way I will keep posted
[CGTW Member
Old 06-28-2002, 10:07 AM   #7
jostrans68
Jostrans68
jostrans68's Avatar
should be here today getting anxious LOL
[CGTW Member
Old 08-03-2002, 02:31 AM   #8
jostrans68
Jostrans68
jostrans68's Avatar
THE moment of truth
I have aligned the rockers and marked them tommorow I will break ou the new toy and see how it works. If it works as advertised the welds shoould almost look factory...Wish me luck......Jack
[CGTW Member
Old 08-03-2002, 06:39 AM   #9
blue_69
someday
blue_69's Avatar
some info would be great i am thinking of getting one too!
Click Here to search ebay for all 67-72 parts
My 72 CST blazer build
72 CST Blazer 4x4
67 2wd swb ( project onion crate )
86 4x4 lwb plow truck
40 x 60 foot barn to work on all this stuff
blue_69 is offline   Reply With Quote
Old 08-03-2002, 08:50 PM   #10
jostrans68
Jostrans68
jostrans68's Avatar
Works great straight up and down like picture proble is the rockers only have a small amount of perfect contact patch it burns through easy on the are that are flat it is great so I wirefed most of it.
[CGTW Member
