Old 06-21-2002, 05:47 AM   #1
68 Suburban
68 Suburban's Avatar
Ladder Bars for Our Trucks?
Has anyone ever seen them? What would be the benefit?
Just sitting here contemplating contemplation.
68 Suburban is offline   Reply With Quote
Old 06-21-2002, 09:47 AM   #2
Low69CST
These are trailing arm replacements right? The benefits should be a stronger and lighter set up. I don't see any spring pads either. My guess would be your supposed to change over to coil-overs?
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 06-21-2002, 09:51 AM   #3
68 Suburban
I have no clue...lol
Old 06-21-2002, 09:51 AM   #4
Low69CST
Also, looking at those, it looks the axle mounting pad is much higher which would lower the truck and I think maybe give it more traction when you nail the gas. I use to be all on top of suspension designs and stuff, but I think by having them designed like that may give you more "anti-squat", not for sure though, gottta read back up on my suspension books.
Old 06-21-2002, 09:53 AM   #5
Low69CST
man, where did you find these things at?? I'm gettin intersted, i'd like to look into them.
Old 06-21-2002, 10:01 AM   #6
Beast388
Suburbans RULE!
Beast388's Avatar
The factory trailing arm type suspension on 2wd trucks is a ladder type setup. These suspensions have been described as excellent if good bushings are installed. Ladder bars are designed to reduce/eliminate axle wrap or hop. They are best used with coil spring suspensions but leafs can be used with special brackets to "float" the axle housing.
I would say there is no reason to use these on a stock trailing arm suspension unless your truck is an all out 9 second truck or similiar. Put some good bushings in and you should have little problem with wheel hop.
--Ben
71 GMC Suburban 4X4
The "Beast"
388 CID Stroker, TH350, NP205, 8-lug D44, 14BFF w/ Detroit, 4.10:1 gears, 4-Wheel Disks 4" Lift, 35" MT/R's.
Beast388 is offline   Reply With Quote
Old 06-21-2002, 10:03 AM   #7
slam33
slam33's Avatar
they don't look long enough to be trailing arms for these trucks
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
slam33 is offline   Reply With Quote
Old 06-21-2002, 10:05 AM   #8
68 Suburban
I dont think they mount in the same position as the trailing arms. They come with frame mounts. I have no clue, that is why I am asking
Old 06-21-2002, 10:16 AM   #9
Low69CST
I'm with beast, theres no real reason to trash our rear suspensions, unless your going with an independent rear. But I also want to learn as much as I can from this. Who knows, i might decide to build the worlds fastest truck one day.
Old 06-21-2002, 02:06 PM   #10
Jesse 67 c-10
Jesse 67 c-10's Avatar
I'd go for a four link set up anyday, lighter, better susp geometry, fully adjustable and it would free up a lot of room for gas tanks, exhaust etc. If you got the axle and frame brackets you could easily piece together a setup with some good tubing and 3/4" rod ends, You can easily play with the susp to get the right amount of lift on takeoff, the possibilities are endless! I definitly want to go with a setup like this some day. The stock susp is great for an old truck but I would change just for easier exhaust routing!
Jesse
Edmonton, Alberta, 67 c-10, Long fleet, front disks, 5 lug rear end, 327 with Vortechs, edlbrock manifold, comp cams XE 256, 600cfm carb. Backed by a getrag 5 speed and 1 piece driveshaft.
1993 Dihatsu Hijet Jumbo cab 4x4, currently converting to battery electric power.
Jesse 67 c-10 is offline   Reply With Quote
Old 06-21-2002, 02:27 PM   #11
imaindianoutlaw
GMC SHORT FLEET F/S
imaindianoutlaw's Avatar
I would like to have a set to replace my crappy control arms I have now
CHARLES WADE HEIN
HVACR FOREMAN.
LEWISBURG U.S.P.
imaindianoutlaw is offline   Reply With Quote
Old 11-17-2002, 06:17 PM   #12
CustomChevy
you want info, go here.
if you are still interested in 4links or ladder bar setup, try these links.
www.competitionengineering.com
www.airride.com
CustomChevy is offline   Reply With Quote
