Old 07-02-2005, 09:24 PM   #1
a28doc
'87 V20 4x4
a28doc's Avatar
Best place to get tcase shifter ext
where is the best place to get a shifter ext for the tcase I need one since I put a 4" lift on the truck it wont shift into 4 lo thanks Doc
'86 K5 Blazer 4x4 FOR SALE
'87 v20 4X4
'99 S10 Blazer 4X4
a28doc is offline   Reply With Quote
Old 07-03-2005, 12:25 AM   #2
ryan68
Certified Chevy Man
ryan68's Avatar
Did you drop your t-case or put on a body lift? Cause otherwise if it went in before, it should go in now.
68 Chevy CST (327,TH400) 3/5 drop lots of fun stuff
71 Suburban 4x4 (350,TH350) 7" lift 37's, D44/14 bolt and other sorts of goodies, lockers front and rear, flexes 40", 895 RTI score
Check out my web site!!! http://www.geocities.com/cst68chevy/
ryan68 is offline   Reply With Quote
Old 07-03-2005, 12:55 AM   #3
a28doc
'87 V20 4x4
a28doc's Avatar
tcase drop I did a front spring with rear blocks lift and it appears the linkage is short now I dont use lo very often but is great when I do lol
Doc
'87 v20 4X4
'99 S10 Blazer 4X4
Old 07-03-2005, 01:56 AM   #4
Americanrider
Thats easy, just find a local blacksmith
Americanrider is offline   Reply With Quote
Old 07-03-2005, 02:03 AM   #5
Mudder
Mudder's Avatar
I just took a piece of steel an inch wide and made an extension for mine. Just drill four new holes in it however far apart you want to extend it.
Og and make sure the linkage isn't hitting the floor.
Mudder is offline   Reply With Quote
Old 07-03-2005, 03:30 AM   #6
ryan68
Certified Chevy Man
ryan68's Avatar
True, make sure it isn't hitting the floor, I've seen that alot with t-case drops and body lifts, Usually then only need to be modified by cutting a 1/2" of so out of floor/boot ring. Although make sure it isn't too close to the floor cause I've seen t-cases pop out of Lo when the body flexes alot.
BTW, why are you using a t-case drop on a 4" lift?
Old 07-03-2005, 07:46 AM   #7
a28doc
'87 V20 4x4
a28doc's Avatar
the lift was done before i bought the truck last fall so was not my idea lol Im just trying to clean up the mess now. thanks for the help guys
Doc
'87 v20 4X4
'99 S10 Blazer 4X4
