Old 07-02-2005, 10:04 PM   #1
Cat Fuzz
My son, my joy.
Cat Fuzz's Avatar
Brakes....need opinions......limited budget...
Ok, I've been putting this off too long. I really need to get on the ball and do something about the front end on my truck.
I have a 69 C20, 8 lug wheels. My drums are shot as well as the hub and spindle on one side. Also have at least one bad tie rod end. New drums cost about $140 each, then along with the hub and spindle I need to replace and the tie rod, it seems like too much money to mess with the old drums. I'd really like to convert to power disks but I need to do it as cheaply as possible. I thought about buying a rusted out 74 C20 from this car lot for $300, but I couldn't be sure if all the parts were good (doubt it). I guess the best thing would be for me to compile a list of all the parts I need so that I can aquire them over time. I know I need spindles, rotors, calipers, MC and PB booster and prop valve. Do I need later a-arms as well? Ball joints?
I'm just a bit confused here on which way I should go. Thanks for the help.
'69 Chevy 3/4 ton, 327cid, Carter AFB, Edelbrock intake, HEI, TH400.
Founding member of the No Money To Spend On My Truck Club.
When your at Home Depot, you WISH you had gotten an 8 foot bed!
Cat Fuzz is offline   Reply With Quote
Old 07-02-2005, 10:07 PM   #2
Randy70C-10
Randy70C-10's Avatar
You can remove the entire front crossmember from the 74 and bolt it to your 69, complete, hub to hub.
Randy70C-10 is offline   Reply With Quote
Old 07-02-2005, 10:50 PM   #3
Cat Fuzz
My son, my joy.
Cat Fuzz's Avatar
I know, but this truck is in very rough shape and I have no way of knowing if the rotors are any good. I'd rather not risk it.
Old 07-02-2005, 10:58 PM   #4
69 longhorn
Its too bad that you are so far from Illinios, I have all the pcs you need collecting dust on the garage floor! YOU DONT NEED TO SWAP IT ALL, your crossmember & a arms will work. on the 20 series, the spindles , ball joints, tierod ends work from 71-87. Swap the later balljoints into your a arms, & bolt the disc spindles up......from there, you need the center link from the later truck(71 on), & also the tierod assys(inner,outer, & sleeves). Best of luck......crazyL
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 07-02-2005, 11:03 PM   #5
GloryHound
Working on a Nova.
GloryHound's Avatar
I know Hotrodmtodd would have what you need, but the shipping from PA would be the killer. I got a used set of rotors, spindles, booster, prop valve, master cylinder, and calipars for I think it was $90. New pads are going to cast about 30 but then you will also need all new tie rods and adjusting sleeves also. Their is a post on the board about attaching 71/72 spindles to 67-70 draglink. You use 71/72 outer tie rods and adjuster sleeves and then some other type of inner tie rod. Then also you would need to put 71/72 ball joints in. I plan on having my calipars rebuilt but looking at them with a little work I think I could make them good again. The last thing you will need are new front brake lines and hoses. On the disc brake set up these lines are a different diameter. You would probably be well ahead to take the junker truck use what you can and then get what you need in the end since it will probably end up being cheaper.
GloryHound is offline   Reply With Quote
Old 07-02-2005, 11:20 PM   #6
Randy70C-10
5 lug rotors are generally less than $40 each new.
Old 07-03-2005, 12:30 AM   #7
Cat Fuzz
My son, my joy.
Cat Fuzz's Avatar
Mine are 8 lug. $80 each new. New drums for current set-up = $140 each.
Old 07-03-2005, 09:18 AM   #8
GloryHound
Working on a Nova.
GloryHound's Avatar
If you get the junk truck and the rotors are bad you should be able to go to a salvage yard and tell them what you need and pick a pair of good rotors for $20 and then get them turned for another $20 if they need it.
Old 07-03-2005, 10:33 AM   #9
Cat Fuzz
My son, my joy.
Cat Fuzz's Avatar
Ok, sounds like buying that donor truck might be the best thing to do. Unless a bunch of the steering linkage is wasted, then it would be pointless. The add said that the motor runs good but the tranny is going bad. If the motor DOES run good I could sell it for what I paid for the truck.
Old 07-06-2005, 05:28 PM   #10
Cat Fuzz
My son, my joy.
Cat Fuzz's Avatar
I got a better look at the truck today. Rotors are shot as well as an outer tie rod and maybe the idler arm. One side has really loose wheel bearing. The truck has leaf springs in the back and 16" white spoke rims. 6 cylinder engine in front of a TH350 that might not be any good. The guy claims it runs but has been sitting for almost 2 years. Not a good body panel on the truck. Rusted bad.
I rechecked the price for new drums @ Napa and they are only about $70 each there but I still need a replacement hub for one side. Anyone have some 3/4 ton parts they want to unload?
Old 07-06-2005, 06:14 PM   #11
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
If you want to make the trip over to Olympia, WA. I have a complete disk brake fromt end over here from under a 71 from rotor to rotor. You can have it free of charge, but you have to remove it... WES www.ClassicHeartbeat.com
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 07-06-2005, 06:51 PM   #12
Randy70C-10
You can't get a better deal than that!!
Old 07-06-2005, 08:04 PM   #13
Cat Fuzz
My son, my joy.
Cat Fuzz's Avatar
Talking
Just to clarify: It is an 8 lug 3/4 ton front end? I'd have to figure out how this would work. Thank you!! Now I just need to work out the logistics and maybe take a couple days off.......Can I haul anything over there from here for you?
Old 07-06-2005, 09:57 PM   #14
drink2mny
drink2mny's Avatar
Hey Cat Fuzz.. Remember the Spokane Swapmeet is this weekend 8-9-10 at the fair grounds...( I gots me a booth)
Could very well find what your looking for there..
Support The Board
drink2mny is offline   Reply With Quote
