Old 07-03-2005, 04:45 PM   #1
skokie
skokie's Avatar
Why
Are the water ports in the back of a 350 blocked off?
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 07-03-2005, 07:23 PM   #2
So GM's cheap intake gaskets will fail and you have to get them replaced or replaced the runied engine.
Sarcasim aside, I wish I knew the reason other than what was just stated.
Old 07-03-2005, 09:14 PM   #3
wolfthing2000
I believe this has something to do with manifold warm up and some 350s are diff. than say a truck 350. I don't know for sure but I remember reading something about this.
wolfthing2000 is offline   Reply With Quote
Old 07-03-2005, 10:34 PM   #4
Sweet72
Sweet72's Avatar
I guess I don't quite understand your question. Are you referring to the expansion (freeze) plugs?
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 07-04-2005, 12:53 AM   #5
skokie
skokie's Avatar
Sweet72. I am talking about the ports circled in red.
68 build thread
Old 07-04-2005, 07:59 AM   #6
72gord
Never enough time!!
72gord's Avatar
My guess is that the heads will interchange from side to side, so they have a water jacket port on each end so if you put the head on the other side it will have a port in the front. That way GM only had to have one casting for the heads, instead of having lefts and rights. Just a guess, make sense?
72gord is offline   Reply With Quote
Old 07-04-2005, 08:15 AM   #7
Zeke
Active Member
so the heads interchange left/right and force coolant through each head to the front then into manifold to radiator. If it crossed in the back coolant could take path of least resistance and cause one head to not cool properly.
1969 C10 350 3spd
1995 GMC 3500 XC 350 dually
When Thomas Edison worked late into the night on the electric light, he had to do it by gas lamp or candle. I'm sure it made the work seem that much more urgent. George Carlin
Zeke is offline   Reply With Quote
Old 07-04-2005, 10:02 AM   #8
neonlarry
neonlarry's Avatar
Actually you can use the back ports and not the front, that is what I will be doing on my modified LT1 intake (drilled for a distributor and water outlets).
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 07-04-2005, 11:20 AM   #9
Gordo
The engine coolant cycle for a stock engine goes like this, the coolant is taken in from bottom of radiator into the pump, then pumped thru both sides of the engine block from front to rear, then pumped up into back end of the heads, thru the heads from back to front, then into front of intake and out thermostat housing back into radiator.
1971 C10 swb stepside 350/700R4/3.73posi (retired as of 4/22/03)
1998 S10 short bed
2002 S10 Blazer
1942 Oldsmobile
1958 Massey Harris Pony
1951 Wife
Killingworth, Connecticut
May those who love us, love us, any of those who do not love us, may God turn their hearts.
And if God is unable to turn their hearts, may he turn their ankles so we may know them by their limping.
A man who works with his hands is a laborer; a man who works with his hands and his brain is a craftsman; but a man who works with his hands and his brain and his heart is an artist.
Gordo is offline   Reply With Quote
