07-03-2005, 05:40 PM | #1 |
soda blasting....
replies on the good, bad and gained wisdom....thanks.
70 LWB, 350/350 A/C, P/S, 3 Tone Paint (white cap, primer gray with black guide coat) |
07-04-2005, 12:48 PM | #2 |
I had my hood and one bedside soda blasted a couple of months ago. It removes all of the paint, but does not remove any metal, or rust, and won't hurt glass or chrome. After the metal has been blasted, it won't rust easily.(unless you sand it). My bedside is still bare, and hasn't rusted even though it got rained on once. The soda is very corrosive, so you want to make sure that it is cleaned good after blasting, but it saves alot of work, especially if you have several layers of paint, like I did.
Wynne 70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s. Build thread 53 Chevy shortbed 69 Camaro Click here to subscribe Chevy GMC International Truck Club Louisiana Charter Member http://www.louisianaclassictruckclub.com |
07-04-2005, 02:28 PM | #3 |
72 BB C30 Super LongHorn
What is a good supplier and tools needed to do this process for the backyard guy without a shop?
I have searched for info on this online but typically they are service sites that sell their services. I would like to do this process myself; and maybe possibly do it on a small scale for those of us in the hobby! thoughts............
72 BB C/30 Longhorn Super HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM HO72 build : http://67-72chevytrucks.com/vboard/s...d.php?t=714492 2017 SS |
07-04-2005, 02:51 PM | #4 | |
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck. |
07-04-2005, 03:06 PM | #5 |
it's not a job suited for a backyard engineer/ you need a VERY large compressor/ a breating apperatuce and suit/ outside hope you have a large property should be at least 100yards away from neighbors and buildings and animals and it will kill the grass
also soda blasting is rapidly falling out of favor with resto shops due to the fact that the paint jobs they did 3-4years ago are starting to fail /also most paint manufactures won't guarantee thier paint on parts that have been soda blasted
07-04-2005, 06:05 PM | #6 |
Is soda blasting the same as aluminum oxide blasting? I had a cab blasted with that from board member jaquesdean in Sneed AL.
07-05-2005, 02:01 AM | #7 |
Saving 1 truck at a time!
Aluminum oxide is different...just another abrasive material that is chemically inert, unlike soda. You are fine as long as you protect it from rust.
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
07-05-2005, 02:35 AM | #8 | |
07-05-2005, 06:38 AM | #9 |
Aluminum oxide is the same material found on most common sandpaper. Basically a mineral like sand. Soda blasting is more like salt. Fine in the dry form but when moisture reaches it, look out. I know a local guy that had a bed blasted and 6 months later with the humidity, the double layers (bedsides to inner sides) looked like an old battery post. All clumped with white crust.
72 3/4 4x4 350 4spd 72 3/4 4x4 350 auto 2004 Duramax Silverado 4x4 2006 Duramax Crew cab 4x4 2010 Harley Ultra Limited 2011 Harley Street Glide |
07-06-2005, 12:09 AM | #10 |
"Trucks with Class"
There is also "media" blasting. These are small plastic balls/beads. Very popular a couple years ago.
I looked at "wallnut shell" blasting on a truck last week. It sure looked good and left a slight etch that should help the primer adhere. Any comments/problems with either of these. I have been using sandblasting for years. It removes all the rust & bondo and leaves an excellent surface that PPG recommends for their epoxy primer. You do have to remove all glass, trim etc. It is good for individual parts & stripped trucks. |
