07-03-2005, 06:00 PM | #1 |
Rear Bags
Rear Bags are done with compressor, tank and solenoid mounted. I've still got clean everything up and will eventually shoot some semi-gloss black paint.
Rob
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 07-03-2005 at 06:03 PM. |
07-04-2005, 12:43 AM | #2 |
All Praise RANDY!!
Nice Work... got the hitch done, and the bag system... you have been a busy bee
07-04-2005, 06:01 AM | #3 |
looks good!
07-05-2005, 12:54 AM | #4 |
Nothing clever
nice...more pictures needed
Got "the Midas Touch!" |
07-05-2005, 10:53 AM | #5 |
Where did you get your air bag brackets?
07-05-2005, 11:16 AM | #6 |
I usde ART (Air Ride Technolgies) Components. http://ridetech.com/ I've done a lot of fabrication, but this was my first Bagging project. It was pretty straight forward, so far, I haven't done the front yet.
Rob
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
07-10-2005, 03:12 AM | #7 |
AttentionDeficitDisorder
looks really good, anymore pics?
08-17-2009, 08:48 AM | #8 |
Re: Rear Bags
Hart Rod
Where did you get those bag "hats"? did they come with the bags? i need a set. |
08-17-2009, 09:17 AM | #9 |
Re: Rear Bags
They came with the bags from ART (air ride tech).
08-17-2009, 11:02 AM | #10 |
Re: Rear Bags
Looks good, Can you post a picture from the side when he is all the way down?
Anybody can restore a classic, takes a man to cut one up..... http://www.arnoldscustoms.com |
08-17-2009, 03:37 PM | #11 |
low n' slo
Re: Rear Bags
x2 on the side pics, i would like too see how low it goes. are you going not notch the frame with a c notch or monster notch? and also, do those top cups keep the drop higher as if you didnt run any cups at all?
08-17-2009, 08:06 PM | #12 | |
Re: Rear Bags
08-17-2009, 08:51 PM | #13 |
low n' slo
Re: Rear Bags
so this is the red suburban right? are you going to run drop blocks and notch the frame too? it looks low already in that pic
08-17-2009, 09:29 PM | #14 |
Re: Rear Bags
Yeah, it's the red one. It's got a cpp bolt in notch and 2" blocks. Here's a couple of more pictures
08-17-2009, 10:14 PM | #15 |
low n' slo
Re: Rear Bags
ah alright, that looks good. so even when it was green it had the notch and blocks? is the c notch sitting on the axle?
08-17-2009, 10:42 PM | #16 | |
Re: Rear Bags
R
08-18-2009, 05:43 AM | #17 |
low n' slo
Re: Rear Bags
how much more of a drop you think you would get with a monster notch?
08-18-2009, 08:00 AM | #18 |
Re: Rear Bags
You could probably get the rockers on the ground, but then you would have to cut the floor and do a different rear trailing arm crossmember.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 08-18-2009 at 08:01 AM. |
08-18-2009, 08:39 PM | #19 |
low n' slo
Re: Rear Bags
man, hard to believe it used to be that green one, hehe. looks good. im gonna have to get with you about the fittings you used with your bag setup, im having a tough time getting mine together!
08-23-2009, 10:24 AM | #20 |
Re: Rear Bags
What size bags did you end up using? I have been debating going with 8" bags in rear and 7" in front (Big Block 3/4). I want to tow with it also. What size tank are you using?
Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
