Old 07-03-2005, 07:33 PM   #1
KenL
Replacing cracked exhaust manifold
Have a 79 4wd Blazer with mildly built 350, driver's side manifold is badly cracked. I'm considering replacing both manifolds with center dump rams horn style cause I hear they flow better. Anyone have any experience doing this in this vintage K5 ? Another alternative might be shorty headers if there are any affordable ones that fit, but I would prefer to keep a more "stock" look for now. TIA
KenL is offline   Reply With Quote
Old 07-04-2005, 12:19 AM   #2
71 shortbedfleetside
71 shortbedfleetside's Avatar
those center dump rams horn exh. man. always crack in the center because that's where all of the heat build up. what about smog legal headers?
71 shortbedfleetside is offline   Reply With Quote
Old 07-04-2005, 01:05 AM   #3
longhorn71
longhorn71's Avatar
i have a set on my 81 2wd blazer and they are great!!The center dump ram horns flow way better then the newer ones too.As said above they do crack easily
longhorn71 is offline   Reply With Quote
Old 07-04-2005, 02:29 PM   #4
KenL
Thanks for the replies. Smog legal headers would work for me, I just haven't found any that are listed as fitting this year Blazer and my current budget. I didn't know about the cracking issues in the rams horn manifolds. I guess I'll need to decide if I'm willing to take a chance on them while I save up for a nice set of headers. Nice to know they work well,though. I'm still worried about clearance issues in a 4wd vehicle. Anyone have any experience in that area?
Old 07-09-2005, 03:03 AM   #5
kevinr1970
Being in WA and the truck being a '79 you don't need to worry about smog legal.
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 07-24-2005, 06:03 AM   #6
Mad Dog
Mad Dog's Avatar
Just a thought..... try tig welding the manifolds, I tigged the pass side manifold 3 years ago. Any half ass decent tig guy should be able to do it. I used alot of heat and nickel rod.
72 C10 longbed 5/7 drop, Telstars, 350/th400(for now)
69 Chevelle SS396 (427/th400)
88 K5 on 35's (355/700R4/208)
Mad Dog is offline   Reply With Quote
Old 07-25-2005, 02:09 AM   #7
KenL
That would have been too simple, Mad Dog! Being a firm believer in making small projects into major ordeals, I found a pair of rams horns at the local junkyard. I got them looking real purty and installed them this week. Spent all weekend trying to make the old set of plug wires fit (they won't), and modifying the old exhaust system to fit (it won't). Local muffler shops won't touch it because its not emissions legal. Part of the fun of modifying is solving a dilemma, but until you find the solution its a real PITA sometimes.
