Old 07-03-2005, 08:50 PM   #1
Lobo'74
Lobo'74's Avatar
Shifter or tranny?
Just took the truck out for a spin. Coming back home the shifter wouldn't come out of first. When I forced it a bit (VERY stiff) I could get it to neutral, but it sounded like the grinding of a non-syncromesh trying to shift. I couldn't get it into second. I was in my neighborhood and got it home in first but had a little trouble parking since it wouldn't go into reverse either.
So, how can I tell if it is the shifter gone bad (that's gotta be rare) or tranny gone bad? Its an all syncro three speed fron a '79. The shifter is an old school Fenton.
"Truck"
'67 small window
'79 350 .030 over, LT1 "clone"
Lobo'74 is offline   Reply With Quote
Old 07-03-2005, 09:15 PM   #2
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
i had a problem with my 3 spd shifter as well it felt real sloppy but mine was 2 nd gear
so i went a bought a new shifter from pep boys for 40 bucks and now it shifts real smooth
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 07-04-2005, 09:17 AM   #3
Lobo'74
Lobo'74's Avatar
I hope its just the shifter, but mine feels like its bound up. I is very difficult to get it out of first and you can't get it into any other gear.
Just prior to this I was teaching my son to drive a stick shift. A little rough, but nothing bad enough to cause any damage.
"Truck"
'67 small window
Old 07-04-2005, 12:14 PM   #4
70GMCer
70GMCer's Avatar
My 3spd on the column used to do that until I changed the linkage bushings.......
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 07-04-2005, 12:19 PM   #5
fastwillie 696969
~Rest In Peace~
floor shifter
by the way mines was a floor shifter not colum
Old 07-04-2005, 04:39 PM   #6
TN70C10
Mine used to bind up all the time between 1st and 2nd and I would have to get under the truck and reset the linkage. It pretty much does it every single time I tried to shift to fast. It wouldnt come all the way out of first before starting to engage 2nd and therefore hang up. I just quit shifting it fast, especially in the rain.
TN70C10 is offline   Reply With Quote
Old 07-04-2005, 06:17 PM   #7
fastwillie 696969
~Rest In Peace~
loosy shifter
try tighten up the shifter assy bolts
Old 07-05-2005, 02:20 AM   #8
Chevyboy1962
C10 now is a GMC
Chevyboy1962's Avatar
Just curious, did this start happening after driving for a bit, or the whole time while driving? I would check the fluid in the manual trans to see if it's low on gear oil. Mine was real low on mine when I first drove my truck home, and the syncro's, gears, etc got hot, and could not get it out of first gear, until the trans was cold, the next morning I went out to the truck, and it shifted fine.
Then again, it could also be shift linkage, clutch, or clutch needs adjustment.
I've also had problems with the Hurst indy floor 3 speed shifter, it would hang up, but would lock the trans with the rear end. I fixed this with new bushings, and tightened the base of the shift kit assembly.
David
*1962 C10 swb fleetside, big window, custom cab 350/TH350 combo...Hot Rod
*1963 C10 lwb fleetside, small window 230/4 speed...Blvd Cruiser
*1931 Ford 5 window coupe (soon to be Hot Rod)... Father & Son project
Chevyboy1962 is offline   Reply With Quote
Old 07-07-2005, 02:52 PM   #9
Lobo'74
Lobo'74's Avatar
Chevyboy1962
It happened after driving it for 20 minutes or so . . . With my son trying to gain proficiency on a manual tranny so it was rough at times.
I will check the manual trans fluid. Clutch has been slipping some lately. Not too bad, no smell or burnt clutch or anything, just slow to fully engage when getting on it (ie: I can't smoke the tires at will like I used to be able to).
"Truck"
'67 small window
