2.5" exhaust manifold
attached is a pic of a 2.5" outlet exhaust manifold. As you can see there is a bracket cast into the manifold. What would it take to cut off and grind the casting to something similar as the other end. Not perfect though close. A little paint, install 'em, and never worry about a header leak again. This manifold is $79+. The LH sells for $94+ and I don't have an idea why.
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck. |
user # 2756
![]() Join Date: Jun 2001
I cut them off of the manifolds on my GMC (vette ramhorns) and cut one bracket off of the driver side manifold of my chevy, I used a 4.5" cut off wheel.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm ![]() |
Keep in mind these are vett. manifolds and they drop straite down. The trucks have a slight kick back to help avoid mounts and such. That being said they will work and work well. I had some on my 327 in my 71, it was a bit harder for the exhaust guy to do his job but he did it. Now I just had a set of custom headers done for my LT1 from sandersons and they are just shy of 3".
Kevin |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
That's the mount bracket for the ac compressor and I have one on my 74 vette. It seems like someone out there would need one and would trade for yours.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
#5 | |
I cut that piece off for a 62 Impala I had years back, and the only thing is that where you cut, it will be smooth and not a rough surface as the rest of the manifold
1997 GMC Sierra Ext 1965 Mustang |
user # 2756
The manifolds on my GMC were new castings for a 63 vette 327, left and right. Got them from GM parts direct for $86 each. I don't know of any center dump ramhorns w/ 2.5" collector that does not have the brackets for alt/AC.
I cut mine off, used a file to shape, used a right angle die grinder with Scotch-Brite pads to smooth up the rest a little and then sand blasted with coarse sand to evenly matte the finish. Wiped with lacquer thinner and finished with Eastwoods manifold Cast Grey coating. They look pretty sharp.
72 3/4 4x4 350 4spd 72 3/4 4x4 350 auto 2004 Duramax Silverado 4x4 2006 Duramax Crew cab 4x4 2010 Harley Ultra Limited 2011 Harley Street Glide |
Eastwood also sells a manifold smoothing kit that has some abrasive rolls to smooth out the whole manifold if you don't mind a bit of a custom look.
"You can take the man out of PA, but you can't take PA out of the man" |
#10 | |
#11 | |
You can also put the manifold on the opposite bank after you do this so the ground off part is facing towards the fire wall and its even less noticable.
On some installations not all you may have to remove a little material from the motor mount stands. Check out this post: http://207.44.196.117/vboard/showthr...7&page=2&pp=25
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
#13 |
tomatocity, I will try to take some tonight.
#14 |
Hope this works
here is one
#15 | |
#16 |
Left side of the pic. Or was it the right?
Seriously it was the left, front side of the engine. This is the motor for my truck so I went with the 2.5" and several other upgrades. You can see the rollor rockers. Just stamped steel version but will help some. The rest of the mods are internal.
#17 |
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
Here are some pictures of the engine in my "Garden Truck". I have the 2 1/2" Corvette manifolds on it. My truck is a 4X4 also. I ground the bosses off of both sides. WES www.ClassicHeartbeat.com
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys Last edited by Classic Heartbeat; 10-04-2007 at 07:34 PM. |
#18 | |
Wes you need to offer these for the less talented or too busy customer. How did you get the surface to look the same (rough)?
#19 |
I cut the bosses off with my cut off wheel and then ground them with my 4 1/2" grinder.
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
#20 |
Same amount of time here but it is worth the work to have such a clean look.
Wes, garden truck my eye. You could eat a salad off that thing.
#21 |
nu2-72, You are wright, you could eat a salad off of it.. But it realy is my "Garden Truck", See the license plate..
#22 | |
Wes, you and GMCPaul really make a 67-72 owner feel inferior. And Paul doesn't list all of his trucks. If both of you lived closer together that would be a truck show in itself.
#23 |
If you look at the bottom left picture, that is the end of the manifold. Just remember when cutting the boss off of it, leave lots of room to grind and smooth. You will see it realy isn't that bad. Just don't remove too much material and go easy on it. You can alway remove a little more material, but you can't put any back!!!
I don't try to make anyone feel inferior, and I'm sorry if I do. I try to educate you with my experience. If you love these trucks as much as I do, you will get there soon! WES www.ClassicHeartbeat.com
