Old 07-06-2005, 07:20 AM   #1
vtblazer
vtblazer's Avatar
Tranny Swap into a 4x4 Question
If I wanted to use a 2wd turbo 400 in a 4x4, what would I need to do?
Is it even possible?
vtblazer is offline   Reply With Quote
Old 07-06-2005, 09:52 AM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Kurt, I believe you'd have to swap tail shafts and then find the correct transfer case and adapter. I believe the TH400/NP205s had 32 splines and no "sleeve" in the adapter.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
