Old 04-13-2002, 02:30 PM   #1
imdarren
imdarren's Avatar
Post Need Steering Help. Round 2
Found the correct coupler at the bone yard. Got it all hooked up. Followed the factory service manual, and filled the pump and started the truck for about 2 or 3 seconds. Then topped off the fluid. Repeated this until the level was good.
When I turn, the pump makes a growling sound the more I turn. Going straight it's quiet. I'm using synthetic fluid. However the bottle says it meets GM specs.
Any Ideas Guys??
Also the steering seems real sensitive. Would a slightly long pitman arm contribute to the growling noise? It looks the correct length. I'm just curious. Darren
Darren
Washougal, Washington
darrengale67@hotmail.com
1972 GMC C1500 (Bone Stock)
Saving / Looking for a 72 SWB 4X4 Or 2WD Automatic with little or no rust.
Washington State
1967 Chevy C10 LWB Rodstoration In Progress.
1972 K20 Cheyenne Super
imdarren is offline   Reply With Quote
Old 04-13-2002, 02:34 PM   #2
Desert Rat
Desert Rat's Avatar
Post
Jack it up,and turn the wheel back and forth ALOT to get the air out of the pump,with the engine off,make sure to keep it full.Dont drive it with a bunch of air in it,or you might be taking that one back for another one.
Desert Rat is offline   Reply With Quote
Old 04-13-2002, 03:49 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
Really, you don't even have to jack it up, but it is easier on the pump if you do.
With the engine running, turn from lock to lock holding it on either end for 1 to 2 seconds. This will 'bleed' the system.
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite.
If you need a pic posted, E-mail me at longhornmail@yahoo.com
Andy, in Columbus Ohio
Old 04-13-2002, 07:51 PM   #4
imdarren
imdarren's Avatar
Post
Desert Rat and Longhornmail,
Thanks! That did it!! I'm the proud owner of a truck with power disk brakes (Last weekend) and now Power steering!! It is awesome! It all works great! Leakes oil from the gearbox and evrything. Just like evryone elses. Also installed the (smaller) Black paded steering wheel from an early 90's pickup. I'm loving life! Darren
Darren
Washington State
