Old 07-06-2005, 10:17 AM   #1
bringit
U-bolt tourqe
I just did a Pro Comp 4" lift and I need to know what to tourqe the U-bolts to on the front springs.The instructions said 60 foot pounds I know it needs to be alot tighter than that.
85 chevy K10 350 crate, headman headers, street avenger carb, accel distrib , rebuilt 700r4, on 33" Super Swamper TSL's, 4 inch Pro Comp lift, shocks, and steel braided brake lines.
bringit is offline   Reply With Quote
Old 07-06-2005, 10:41 AM   #2
ryan68
Certified Chevy Man
ryan68's Avatar
If they are 5/8" u-bolts, they should be torqued to about 110-125 ftlbs.
68 Chevy CST (327,TH400) 3/5 drop lots of fun stuff
71 Suburban 4x4 (350,TH350) 7" lift 37's, D44/14 bolt and other sorts of goodies, lockers front and rear, flexes 40", 895 RTI score
Check out my web site!!! http://www.geocities.com/cst68chevy/
ryan68 is offline   Reply With Quote
Old 07-06-2005, 11:00 AM   #3
bringit
Thats what I thought because I did the rear to that (a month before). But my question now is who is the moron at pro comp that made that mistake? That could be dangrous to those that wouldnt second guess the instructions.
Old 07-06-2005, 01:11 PM   #4
ryan68
Certified Chevy Man
ryan68's Avatar
Yeah, something wasn't right there. Just be sure to re-torque them after 100 miles and flex the suspension a little before you do.
Old 07-06-2005, 02:33 PM   #5
Mudder
Mudder's Avatar
I always tightened them as tight as I could get them. And like they say, retighten after driving a few miles.
Mudder is offline   Reply With Quote
Old 07-07-2005, 03:23 AM   #6
4x4Poet
Exactly how tall are the nuts ProComp provided for the u-bolts? And are they nyloks?
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 07-07-2005, 06:50 AM   #7
bringit
They said they were nylocks in the instructions, and Im guessing here but there about 1 1/2" tall.
Old 07-08-2005, 06:55 AM   #8
4x4Poet
Wow! That's some tall nuts.
Did I just say that?
Most tall u-bolt nuts I've seen are 3/4" tall. 3/4" tall nuts on fine thread 3/8", 1/2", and 5/8" u-bolts can take a lot of torque. Around 80 ft-lbs for the 3/8" bolts and over 100ft-lbs for the larger bolts. With tall nuts, it sounds even dumber that ProComp recommended such a low torque setting. I asked about the nuts' height and if they're nyloks because I've seen some lift kit makers supply 1/2 tall nylok nuts that don't have enough thread to allow for high torque settings. In fact, I think they supply the nyloks in an effort to keep bonehead DIYers from having the u-bolt nuts loosen and cause road failures.
My local spring shop strongly recommends using tall, grade 8 nuts with thick grade 8 washers and no lock washers. Just put a little oil on the threads to stop heat buildup during tightening and to get a sure torque setting.
Can you post a pic of the u-bolt nuts with a frame of reference? One and one half inch tall nuts doesn't sound right, IMO.
