Old 07-06-2005, 11:13 AM   #1
Green Machine
Green Machine's Avatar
Put gas tank over carpet or not ??
I have new full length carpet for my '68. The gas tank has the thick tar paper shims under it. I would like to sit the tank on the carpet and eliminate the shims, but that will also space the tank mounting bolts away from the cab. Should I trim the carpet, so the tank sits on the carpet on bottom, but cut front side so tank can bolt straight to bab without carpet in between ? There is not much room between cab and tank and don't want tank to hit seat or does 1/4 inch matter ?
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 07-09-2005, 01:52 AM   #2
Green Machine
Gonna put er in tommorow afternoon, any thoughts ? Thanks
Old 07-09-2005, 06:38 PM   #3
XXL
Seņor Member
XXL's Avatar
I'd notch the carpet. Too much work taking the tank loose just for what you're suggesting.
XXL is offline   Reply With Quote
Old 07-09-2005, 07:55 PM   #4
cdowns
cdowns's Avatar
carpet retaining moisture will cause rust on the tank bottom
