Old 07-06-2005, 02:03 PM   #1
hobbz
hobbz's Avatar
quadrajet vacuum line help
please refer to the pics, do i have the vacuum line comming from the distributor in the correct place? the q-jet i took off had it on the other side of the fuel filter...
thanks for the help again
it is the middle one
hobbz is offline   Reply With Quote
Old 07-06-2005, 03:19 PM   #2
71-longbed
Its Magically Delicious
71-longbed's Avatar
take the hose off of the dizzy while the engines running .. if you can feel vaccum @ idle then .. that manifold vaccum ... if there no vaccum @ idle then that's ported ...
some guys run vaccum advance on manifold and some ported .. i like manifold myself
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Of all my favorite things to do, The utmost is to have a brew.
My love grows for my foamy friend, with each thirst-quenching elbow bend.
Beer so frosty, smooth, and cold it's paradise pure liquid gold.
Yes beer means many things to me that's all for now cus I gotta pee.
71-longbed is offline   Reply With Quote
Old 07-06-2005, 08:54 PM   #3
71-longbed
71-longbed's Avatar
this might help .. although there refering to a 502
http://www.netwelding.com/ignition_timing.htm
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Old 07-06-2005, 09:36 PM   #4
Earl Filter
Earl Filter's Avatar
Mine is hooked to the vac line pictured above the fuel inlet, which looks capped. That one is manifold vacuum, which pulls vac even at idle. It doesn't seem to affect mine negatively.
Real Name - Brandon
Current Vehicles:
1977 C20 Silverado 454/TH400 3.73s
1989 Jaguar XJ6 in the middle of an LT1/4L60E swap
Earl Filter is offline   Reply With Quote
Old 07-06-2005, 10:39 PM   #5
SSC's76
No No
SSC's76's Avatar
In all honesty it doesent matter. GM swiched to a ported source to lower emmisions @ idle, cheap but effective cure. Some engines run better off of a ported source usually the ones with small cams or engines that pull a good amount of vacuum @ idle. Engines with larger cams that dont pull alot of vacuum tend to run better off manifold "full" vac. Try them both and see which your setup likes.
1976 Custom Deluxe SWB Med FMB.3/4 Drop.
Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out.
1997 K1500 ext cab 5.7 stock except muffler
SSC's76 is offline   Reply With Quote
