Old 07-06-2005, 05:28 PM   #1
tomatocity
tomatocity's Avatar
Correct Fan Blade Size?
There seems to be no consistant answer to the 19" or 18" 7-blade fan. The next time you are under your hood I would appreciate you grabbing a tape measure and measuring the fan blade. Also pleae measure the opening of your fan shroud. Mine is a 19.5" diameter. Thanks in advance. Tim
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck.
tomatocity is offline   Reply With Quote
Old 07-06-2005, 06:53 PM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Shroud on mine is 19 1/2", blades are 6" x 3 3/4", total fan dia. is 18". HTH!
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 07-06-2005, 07:04 PM   #3
skokie
skokie's Avatar
Mine is 18 inch fan with about a 19 inch opening. Non ac though
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 07-07-2005, 01:23 AM   #4
tomatocity
tomatocity's Avatar
stocker and skokie: Thank you. Is the fan bolted to a fan clutch? The fan shroud I just bought has an opening of 19.5".
Old 07-07-2005, 01:24 AM   #5
skokie
skokie's Avatar
Mine is bolted to a fan clutch. Also forgot to mention it mine is a aftermarket. Not stock.
68 build thread
Old 07-07-2005, 08:47 AM   #6
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Yes it is. I have owned the truck for 28 years and I'm 99% sure everything is OEM. And it is an A/C truck, though the R12 is long gone.
On a side note, the clutch unit is 2-piece, like a sandwich. The front and rear halves are bolted together, and the vanes (inside) run in a temperature-sensitive silicon fluid, which I have only found at Toyota dealers. Also, the clutch unit has the bi-metal spring at front & center.
- Mike -
RIP El Jay
Old 07-07-2005, 08:08 PM   #7
tomatocity
tomatocity's Avatar
thanks again.
