![]() Join Date: Apr 2005
Rebuilding trailing arms question
I've got a set I'm going to blast, repaint and put in new bushings. Anything else I should do sense I have them out? Weld seams? I've seen the plates that you can weld on, what is the purpose? Is it worth it? Thanks for info.
Rob
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
anyone???
67 is sold
I saw a discussion on those add on plates a while back. It was stated they don't really do much for a driver, but more if you pull/haul heavy loads on a regular basis.
I just burned the old bushings out of my trailing arms this past weekend ![]() What bushings will you run? I bought the poly bushing kit from PST |
Weekend Warrior
Mine were starting to "split" down the seams...so i clamped them back together and welded every 2-3" a 2-3" bead on both the top and bottom.
no need to weld them solid. might not hurt to put some seam sealer in the seam if they are in good shape or after you weld them to keep water and dirt out for future rust/split prevention.
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered ![]() ![]() ![]() Last edited by arkracing; 07-07-2005 at 09:11 AM. |
I got some from EST. Never thought about the seam sealer, that is a very good idea
![]() Rob
Keepin an eye out
How do you know when the bushings are bad?
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
Cantankerous Geezer
All that I have seen have gotten gravel and dirt between the pieces. I cleaned them out, put bolts in to hold the pieces together, and painted. You could weld instead of bolting. The plates are usually used for reinforcing a rusted out area.
Fred There is no such thing as too much cam...just not enough engine. ![]() |
I did the same as arkracing w/a 1.5" bead about every 6" the length of the arm, top & bottom, on both my trailing arm trucks. I also boxed the front & very rear of the arm as well on my RestoRod.
Both use urethane bushings.
Scoti,
Do you have any pictures? Thanks, Rob
#10 | |
#11 | |
'68 Short Step LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc Last edited by 68LSS1; 07-08-2005 at 03:42 AM. |
