07-06-2005, 11:16 PM | #1 |
Psalm 23
Turning signal issues
I have a slight problem..more of an inconvienance really. My turning signals are SUPER sensitive..if they are not in exactly the right spot they will blink. Also when I turn them off to take a turn after completing the turn I have to manually turn them off. There is no canceling switch. What kind of parts would I need to fix this problem and what kind of money can I expect to shell out for the parts?
By the way I've been having a blast driving my truck around!...I love this thing I'm hooked. Thanks alot for any comments, ideas or suggestions. Kevin
71 GMC Fleetside C15(cab), 3/4 ton, 350, Holley Street Avenger 570cfm carb, TH350 trans, Leaf-springs, 2WD. "Peter are you sleeping on the job? No I have a bug in my eye and I'm trying to suffocate him." - Family Guy |
07-06-2005, 11:22 PM | #2 |
Designated Grumpy Old Man
Sounds like the return springs are broken. Pull your steering wheel off and look for two springs about the the diameter of a pencil. They should have one end that is angled 90 deg from the circle, if not then it is broken. Some one should have a picture here of what they look like. Chev sells them and I think they are pretty cheap.
Never let the truth get in the way of a good story 71 Chev 1/2 ton 4X4 LWB Fleetside SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=361222 http://www.youtube.com/watch?v=1LgREwtDfaA 68 Chev 1 ton flat bed http://www.youtube.com/watch?v=0bO8szzlD4A 56 Chev Handyman Wagon http://www.youtube.com/watch?v=9y-6ddpBTkM http://www.youtube.com/watch?v=lbLzZ7zY8wA 56 Chev Belair http://67-72chevytrucks.com/vboard/s...d.php?t=410667 http://www.youtube.com/watch?v=xoW0Ei7ZNIg |
07-06-2005, 11:29 PM | #3 |
Psalm 23
That would be great if thats all it is..I'll go look for those right now.
Thank you.
07-06-2005, 11:46 PM | #4 |
You can buy a pair of cancelling springs in the Help! section of just about any auto parts store.
07-07-2005, 12:03 AM | #5 |
Psalm 23
Yeah I'm not seeing any...i don't know where exactly to look but I see no springs.
I was looking online at that part and I have a question. Whats the difference between a canceling spring and a TURN SIGNAL CANCEL CAM? oh yeah and as you can see from the last pic my emergengy flasher deal is broken Thanks
71 GMC Fleetside C15(cab), 3/4 ton, 350, Holley Street Avenger 570cfm carb, TH350 trans, Leaf-springs, 2WD. "Peter are you sleeping on the job? No I have a bug in my eye and I'm trying to suffocate him." - Family Guy Last edited by R@nger; 07-07-2005 at 12:13 AM. |
07-07-2005, 12:14 AM | #6 |
YES_____NO
The differance is between the canceling spring and a Turn signal cancel cam. is that the spring is just the sping and the cam is the whole white thing that you see in you pics.
People many not remember what you said or what you did, but they will remember the way you made them feel. - unknown Cause, remember: no matter where you go... there you are. - Buckaroo Banzai 1984 Help support the board Last edited by Mongo; 07-07-2005 at 12:14 AM. |
07-07-2005, 12:19 AM | #7 |
Psalm 23
ahhh ok. ty.
So to just replace the springs am I gonna have to get a steering wheel puller to get to where I can put those springs in?
71 GMC Fleetside C15(cab), 3/4 ton, 350, Holley Street Avenger 570cfm carb, TH350 trans, Leaf-springs, 2WD. "Peter are you sleeping on the job? No I have a bug in my eye and I'm trying to suffocate him." - Family Guy Last edited by R@nger; 07-07-2005 at 12:39 AM. |
07-07-2005, 12:56 PM | #8 |
Yes
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
07-07-2005, 07:23 PM | #9 |
Psalm 23
And done...I got all my parts and steering wheel puller today and put those springs in place. Now it works like a charm...ty guys for the help.
