![]() Join Date: Jun 2004
Help w/rebuilding truck tilt....
I bought a truck tilt for my 69 short step. After getting a 'good' condition tilt column it appears that it needs work. Pointer replaced along w/some new shaft bearings and pointer housing w/lense. Also the signal housing is bent and dented up. So Is there anybody who would like to rebuild this for me? I could do it but don't want to spend the time to learn a tilt column. It will need paint when done too. Who's up for the challenge and what would it run me $ wise.
John in MI
Locab36 1936 low cab 1/2 ton ![]() 1956 BMW R25/3 1968 Moto Guzzi V7 1969 BMW R100/2 1986 Silverado SWB ![]() 2007 Harley FLHTP 2011 GMC SWB 4x4 Z71 ![]() http://www.flickr.com/photos/locab36...7623329816080/ |
I'd like to get mine rebuilt too. It squeaks real bad when it's cold.
68stepbed,
I assume that your squeek is when you turn the steering wheel. If that is when the squeek happens try greasing the horn brush. You might also try some oil on the lower bearing. The upper bearings are pretty well greased and I doubt if they are making the noise. Jim |
