Old 07-07-2005, 12:14 AM   #1
whitesswj
Embrace the Redneck
whitesswj's Avatar
oil pressure
I just changed my oil guage (factory) to a better looking one.
Once i made the change i noticed that when i brake the pressure goes way done. I mean below the L mark. I know the oil goes toward the front of the oil pan when i do so but below L, What??
also, i put a quart in it tonight - i needed it- and i noticed that the PSI is Dead Center at 60 MPH. If i take it above 64 or so, the pressure goes down. Now i know that aint right. What's going on here guys?? Should i put the other guage in it and see if i've got the same thing?
sswj
'01 Camaro
Son, you just can't get there from here...
whitesswj is offline   Reply With Quote
Old 07-07-2005, 12:51 AM   #2
jhow66
jhow66's Avatar
yep
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 07-07-2005, 06:04 AM   #3
byrd
Union Electrician
byrd's Avatar
Did you put in an 80 lb gauge where as before you had a 60 lb gauge? Is your oil pump getting weak or screen is clogged? Randy
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 07-07-2005, 11:05 AM   #4
farside847
farside847's Avatar
The stock one should be near the middle at idle, then go up with high RPM.
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree
farside847 is offline   Reply With Quote
Old 07-07-2005, 03:34 PM   #5
whitesswj
Embrace the Redneck
whitesswj's Avatar
both were stock guages. I thought they were both the same. how can you tell the differance.
'01 Camaro
