Orange Truck
![]() Join Date: Jun 2005
1969 Chevrolet C10 - My steering wheel is in excellent shape except for a stress crack in the round plastic portion that fits around the steering column. The crack is about 1/8" wide at the top just above the horn button. Can this be repaired in some manner. It is sort of a dark deep green in color. I have considered a filler or possibly using a C clamp and glueing back together, if an appropriate adhesive could be determined. Any experiences or comments welcomed.
![]() Join Date: Jul 2000
I used Bondo over ten years ago to repair steering wheel cracks and repainted it, cracks are still invisible.
68 Short Stepside, 350, quadrajet, 700r4, 3:73 posi, power front discs, HEI, Factory Air, Tilt, Tach, accelerator cable instead of rod, sway bar. 96 Impala SS 97 Monte Carlo |
Red
I've wondered about this myself. My wheel is in alot worse shape than yours,though. What about using a 5 min epoxy(to fill the crack), I guess you'd have to find a paint that matches your wheel (might not be easy?). I've not heard of any kits for example, that are designed for this type of repair, maybe someone else has?
Mike
'72 Cheyenne LWB 350/350 "The sun don't shine on the same dog's ass all the time." - Catfish Hunter (commenting on why he was not able to pitch another perfect game). |
Where's my beer?
I beleive the Eastwood Company sells a plastic steering wheel repair kit just for fixing cracks. I think they are at Eastwoodco.com.
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam. 79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam. '03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great '08 Tahoe LTZ 4x4 155K |
use the fiberglass filler, it is green around here. Maybe add red dye to make it blue
or primer and paint it. ?
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
I have seen wheel repair kits on line before but can't remember who had them. One thing I don't think I'd try is the reclamping method as you would most likely run into seperation problems again. The filler idea sounds like the way to go. Doug
67-72 Addict!
I have used Bondo with success but these were trucks I was selling. My buddy swears by PC-7 epoxy for filling cracks in plastic. Clean, sand, seal, prime and paint!. POR-15 sells a kit (pricey at $70). I have seen epoxy putty in craft stores reasonably priced for people who make sculptures also. If you still have manual steering, I wouldn't waste my time fixing it due to the stress of the manual gear box. My 2 cents!
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
What about JB-Weld?
whatabout epoxy then add your color to that while mixing seems to me that woud be the way to do it. you can get colors from craft stores then just play with the colors on something else till you get it right.
![]() ![]() Last edited by pickemup; 07-07-2005 at 10:08 PM. |
Why don`t they call it "Golden Bullet"?Must not want to push it like the lite stuff.Get it?Gold can/Golden,CO?One of the many things I ponder...Now about steering wheel cracks,colored epoxy,hmmm....
