Old 06-21-2002, 07:04 PM   #1
DevinM
DevinM's Avatar
Question Backfiring while accelerating. Help please.
My 71 SWB has a 350 in her. Last week, she was running fine. But today (no major change in the weather), under acceleration, she wouldn't stop popping. W/T/F. After my drive was done, I let her sit in my garage and idle. I noticed small pops (nothing real noticeable) coming out of the passenger side exhaust pipe. Any suggestions before I have a "deep pocket mechanic" look at it?
'71 Chevy C-10 - Current
'62 Imapla SS - Traded for my current
'73 Nova Hatch - traded for ATC-350X
'73 Chevelle Deluxe - First car (R.I.P)
DEERFIELD, MA
DevinM is offline   Reply With Quote
Old 06-21-2002, 07:20 PM   #2
tom hand
CCRider
tom hand's Avatar
First do a "redneck" test. Go out tonight after it is real dark, crank the engine and open the hood. If you have any bad spark plug wires crossfireing you will be able to see it in the dark. Next take a good look at your distrubitor cap for cracks or carbon. To make it pop like that if the ignition is the problem it is crossfireing somewhere. If you can't find a problem there next thing to do is a compression test. I bad valve could cause that and you will know after a compression test. I hope it is something easy.
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 06-21-2002, 07:50 PM   #3
COBALT
COBALT's Avatar
Yeah, sounds like a plug/wire/distributor problem. I don't think it's points or you'd be missing out vs. popping.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 06-21-2002, 08:15 PM   #4
70 Jimmy
aka Crusher, Crushergmc
70 Jimmy's Avatar
Talking
The real "redneck" test is to reach in and grab the distributor cap. If it shocks the livin' crap out of you, then you have a bad cap! hehehe
"KEEP IT DOWN!"
70 Jimmy 454 2wd
56 GMC Big Window
"It's funny till someone gets hurt, then it's freakin' hilarious"
70 Jimmy is offline   Reply With Quote
Old 06-21-2002, 09:05 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
At an idle, put your ear right over the carb, if you hear a popping (not a mis) you may well have a bad intake valve.
Again, at an adle, place a dolar bill over the opening of your tail pipe, if it gets sucked in and blown back out over and over, you probably have a messed up exhaust valve.
Of course you could do a compression check to confirm messed up valves too, but this is quicker.
Old 06-21-2002, 09:31 PM   #6
Model 12
Sounds like a sticking valve...
If James Dean had a truck, it would be a Cheyenne Super...
Model 12 is offline   Reply With Quote
Old 06-21-2002, 10:36 PM   #7
DevinM
DevinM's Avatar
THANKS GUYS! I went out into the pitch black and did the examination. Well, every plug (in the white area of the sparkplug) appeared to have a "faint" glow (rather than a sharp white spark) EXCEPT for one. So I turned the lights on and checked the area. Well, the darn boot was almost hanging off the plug. I re-attached, and away I went....NO MORE BACKFIRING! "I love it when a plan comes together." Thanks again.
DEERFIELD, MA
Old 06-21-2002, 11:30 PM   #8
tom hand
CCRider
tom hand's Avatar
Sometimes "redneck" tests work the best. Glad it was a small problem.
Olive Branch MS
Old 06-22-2002, 08:05 PM   #9
chevy72402
FARMER/RANCHER
chevy72402's Avatar
longhornmail, It is supposed to kinda flutter and sometimes it will go back and forth really fast....
1972 chevy super, long box, 402 big block (2,000 miles on rebuild) 2wd tach, tilt, tool box on bedside, a/c, sliding rear window, orange and white.
1972 Chevy Blazer 2wd, tach, tilt, a/c, my first engine overhauling experience, Orange, with white top
2006 Gmc Sierra, XM, Z-71, dark blue, onstar, leather, rear entertainment (audio only) heated seats, (the wife loves that feature) upgraded tires immediately after purchase to Goodyear Wrangler AT/S (hate those rock throwers that come from the factory)
BWC
chevy72402 is offline   Reply With Quote
Old 06-22-2002, 09:50 PM   #10
Longhorn Man
You mean when it is running properly?
On a stock engine, in good tune, it should be wavin like a george washington flag.
