Old 07-07-2005, 04:19 PM   #1
jamal
jamal's Avatar
air bags
How hard is installing an air spring set up in a 67 chevy truck? It seems easy as the air bags replace the coils, but just wondering if anyone has tried it, and the pros and cons of installing this. This truck will never haul anything so dont have to worry about that.
67 chevy stepside, 6 cylinder, three on the tree, small window. Currently in resto.
jamal is offline   Reply With Quote
Old 07-07-2005, 04:40 PM   #2
Putter
More Cowbell....
Putter's Avatar
If your truck already has coils/trailing arms in the rear, then our trucks are in the list of 'easier-to-do' trucks. The rear ones bolt right in place of the coils and the fronts just require a mounting plate. You can get as fancy as you like, but it is pretty straight-forward.
You might want to consider a longer track bar.....like the SuperTrac.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 07-07-2005, 06:21 PM   #3
Hart_Rod
Hart_Rod's Avatar
Couple of links:
http://67-72chevytrucks.com/vboard/s....php3?t=152897
http://67-72chevytrucks.com/vboard/s....php3?t=129463
Rob
Hart_Rod is offline   Reply With Quote
Old 07-07-2005, 08:47 PM   #4
jamal
jamal's Avatar
Thanks those articles helped, I think I may try installing them
