Old 07-07-2005, 07:01 PM   #1
BigOrange
Trans cooler question?
I got a new aluminum radiator, but it doens't have a trans cooler set up. Do I have to have the trans cooler lines hooked up or can I just bypass them? Any Help would be appreciated.
BigOrange is offline   Reply With Quote
Old 07-07-2005, 07:12 PM   #2
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Bypassing them is possible, but I do not reccomend it, go to your
local parts store and get a aftermarket trans cooler kit, say $30.
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 07-08-2005, 12:51 PM   #3
70GMC_BOB
My burb had the one in the radiator and an external aftermarket one installed in series by the p.o. He used it to tow a 36' boat.
1972 chev c20 2wd lwb 350v8/th350. (dad's)1970 gmc longstep (9ft commercial bed), 1 ton, 2wd, 350/th400.
70GMC_BOB is offline   Reply With Quote
Old 07-08-2005, 01:22 PM   #4
COBRO
Active Member
Talking
Yep you need to mount a ext.cooler in front of the radiator and it will work fine - the cooler in the radiator not only cools but heats the ATF up in the winter to operating temp so give it a little time to heat in the winter and you should be good. Doesnt get that cold at the coast anyway. :::CB
COBRO is offline   Reply With Quote
