Old 07-07-2005, 07:09 PM   #1
papony
1967 C40 Brake Parts?
Does anyone know where I can find 1967 C40 brake parts (new or used)? I need the power booster, master cylinder and wheel cylinders. Or does anyone know of a dual bowl master cylinder conversion kit for a C40? email papony@velocity.net
papony is offline   Reply With Quote
Old 07-07-2005, 09:51 PM   #2
Pretty rare there.Can you get a look at the GM parts book and get a part#?Maybe someone here can help you with that.zit may be the same # as an other more common application.
Old 07-07-2005, 11:14 PM   #3
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
Raybestos still has 'em, here's the link to the search page. Just enter 1967, Chevrolet Truck, 40, 400, 4000 series.
http://www.raybestos.com/catalog/consumer/icat.html
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 07-08-2005, 11:51 PM   #4
67_C-30
I have a radical idea!
67_C-30's Avatar
There are also a couple of different brake systems for those truck. I could not get any parts from Raybestos for my truck. My '67 C-50 has the Midland Brake set-up which has the firewall mounted vac booster with single bowl, single line master cylinder. I had to buy a new (no rebuilt available) Bendix master cylinder for mine, and they are pricey!! My truck also has dual wheel cylinders on each wheel. If you need everything, you could easily tie up $1000 - $1200 in parts alone. I was lucky to get away with just replacing the $350 master cylinder.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
