Okay, maybe not a whole lot, but enough to be annoying. I have a vibration that comes in at about 50-55 mph. It starts very small, gets faster, then goes away. It cycles every second or two. The truck has all new stuff in the front, rebuilt 400 trans and new driveshaft. My guess is that it's something in the rearend. So what do ya'll think? Wheel bearing, bent axle, gears?
We made Oklahoma a little after 3, Randy & his brother Bob & my old GMC... |
Living In The Past
could be as simple as tires not balanced. Maybe a wheel weight came off or you got a tire going bad. I had a brand new tire warp on me once so bad you could visibly see it, and is shook the he11 out of the truck
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
Could also be your flywheel. If it is cracked it will vibrate also. WES www.ClassicHeartbeat.com
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
is it a LWB?
I had this happen on my suburban and it was the rear carrier bearing. took mine to a local drive shaft shop and the replaced two u-joints and the rear-carrier bearing for $134 out the door. |
First, easiest, cheapest thing to check is the tires for ballance or a defect.
I got a bench seat baby, you don't have to sit over there. |
When I used to drive the big trucks I had that happen a few times and it was either u-joints, carrier bearing or the splines binding on the drive shaft.
Remember "New" is not always perfect.
Currently helping a Friend build a 71 Custom Camper into his dream truck ![]() Guess that makes me the Middle man since he asks questions and I search for the answers ![]() |
Sounds like a u-joint. Take it drive shaft back and let them ckeck it.
72 CHEYENNE 10 SUPER 468/400/3.73 |
Thanks for the suggestions. I have this terrible habit of diving way farther into a problem than is required only to find it was a simple fix. I'll check tires, alignment and u-joints first.
