Old 07-07-2005, 10:48 PM   #1
Don Smith
Heat stove for small block
WTB Heat Stove for small block.
68 Short Stepside, 350, quadrajet, 700r4, 3:73 posi, power front discs, HEI, Factory Air, Tilt, Tach, accelerator cable instead of rod, sway bar.
96 Impala SS
97 Monte Carlo
Don Smith is offline   Reply With Quote
Old 07-08-2005, 09:17 PM   #2
Don Smith
Ttt
96 Impala SS
97 Monte Carlo
Old 07-09-2005, 12:13 AM   #3
67_C-30
I have a radical idea!
67_C-30's Avatar
I have this one off a '69 C-10. It is in excellent shape, and has what I beileve to be the original paint on it. I would let it go for $25 to your door.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 07-09-2005, 12:33 AM   #4
Roberty
Hot Damn - Here I Am!!
Roberty's Avatar
The Heat Stove is the metal shroud that goes around the original exhaust manifold. That's the heat stove riser tube that you show in the picture. He might be needing both though.
My vehicles:
'90 Silverado Sport
'71 Chevelle SS Convertible
'70 C-10 - My Grandfather bought it new - original un-restored
Roberty is offline   Reply With Quote
Old 07-10-2005, 05:25 PM   #5
Don Smith
67C-30, Thanks for reply but I need the part in Roberty's post.
96 Impala SS
97 Monte Carlo
Old 07-13-2005, 12:40 AM   #6
knsmodels
I make Models
knsmodels's Avatar
Don....I have a complete set up of the heat stove to the air cleaner.....pipe is the short pipe (not long reach).....the stove itself has some very thin areas also some metal gone around the exhaust bolt (see arrows)....The stove looks fine on the truck you really cant see the rusted area once in place....I had it on my truck and it fit securely....the pc behind the manifold is in really good shape and holds it in place quite well......comes with bolt for exhaust manifold.....it is not perfect but better than nothing.....$30 shipped if you want it.....Paul
PS stove is shiney as I had painted it with cadmium paint
Click to see what I do
1972 LWB K10 350/4 sp
1968 SS Chevelle 396/tremac5spd
knsmodels is offline   Reply With Quote
Old 07-13-2005, 10:02 PM   #7
Don Smith
knsmodels, thanks for the reply but I think I will continue to search .
96 Impala SS
97 Monte Carlo
